Results 1 to 8 of 8
Thread: ARB Drop Links - Top/Bottom Difference..?
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Default ARB Drop Links - Top/Bottom Difference..?
    Collected a pair of genuine GM front anti-roll bar drop links from the stealers today; they're still in the plastic wrapping so I haven't had a thorough inspection yet, but there doesn't seem to be any difference between each end of them - is there a top and bottom, or can they be fitted either way up? The retaining nuts have different part numbers for the top than for the bottom, and two of the four nuts have a wider flange on them. Any ideas?
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Engine : Z19DTH
    Isn't it easier to see how they fit after you remove one from the car and inspect it?
    Larkhall
    I got aftermarket ones yesterday and both ends look exactly the same. im getting them fitted tomorrow, but as Lao said, best bet is to take them off first and see if there's any difference with the ones on the car just now
    May 2009
    S.E
    Quote Originally Posted by Lao View Post
    Not if the ones on the car aren't the originals, and weren't fitted by Vauxhall.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Engine : Z19DTH
    I don't think it matters what way you mount them really. I'm sure you can sort it out after you remove the old ones.
    Regular Member old cruiser's Avatar
    slough
    either way round mate.
    Cheers Pete
    May 2009
    S.E
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Thanks fella.
    slough
    No problem mate, and if you need it, the torque setting for the nuts is 65Nm (48 lbft)
    Cheers Pete
  1. drop links
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 18th June 2012, 23:27
  2. Drop Links
    By Exclusive BV in forum The 'Off Topic' room
    Last Post: 6th March 2011, 22:37
  3. Drop links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 13th February 2011, 11:13
  4. Drop links
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2009, 20:10
  5. Drop links
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 21:45
