Results 1 to 10 of 14
Thread: uprated brake discs
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default uprated brake discs
    Hi guys....need to replace front discs....has anyone fitted grooved and drilled? are there any associated problems with them? also mine has 285mm can I go any bigger without changing calipers.....appologies if this has been listed before . thanks Andy
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    upgrade wise load's of folk have gone to the 314's from gsi's but a ferw of us have gone to 302's as much cheaper option, try new disk's and pad's the same size but go for green stuff pad's and drilled disk's if you dont want hastle changing calliper's...
    hth
    Midlands Mod Shop - NFFC.
    Jun 2009
    bradford
    Quote Originally Posted by ditchp View Post
    hth
    thanks for the reply Ditchp- so I can't put any bigger disks on with these calipers then?
    Slough
    72 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    no you cant m8 as you need the carriers and new calipers .khalid
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    on my vectra b sri that i had before the veccy c, i had ebc drilled and grooved discs and greenstuff pads, worked a treat and looked good behind the rims, i think i paid about 160 quid all in but it was about 3 years ago, as and when i need to change the discs on my current vectra i think i'll be going down the same route
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Check if Saab are likely to be selling any more of the 314s, they stop better, are much more progressive & probably wouldn't work out any more expensive than uprated 285 discs & pads - I can highly recommend the 314s
    Jun 2009
    bradford
    Quote Originally Posted by Ian S100 View Post
    do I need to ring a saab dealer or do you have any links, thanks for all you responses guys
    Mar 2007
    Southport
    PM sent
    Jun 2009
    bradford
    PM sent
    thanks Ian..........your a diamond......from what model fits exactly to a veccy?
    cheers againn
    Regular Member david.aka.judas's Avatar
    Suffolk
    I spoke to the chap at saab and the 314mm kits had long gone, he had some because the saabs had gone away to be modified - so the original 314's had to be taken off.
    speak to dan at LMF, there was a possibility that he may be getting more in.
    they had one set for £350 plus postage but I bought it........muhahaha.......lol
    you could go down the route of ebc green and disks - you will see a benefit, also speak to HEL in exeter for a full set of braided lines - I've got some and it was only £50.
  1. Uprated brake fluid-what should I use
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2012, 15:32
  2. What brake discs??
    By DaMan1000 in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2010, 20:04
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. What brake discs
    By arnie_barney in forum Introduce yourself.
    Last Post: 10th November 2009, 17:49
  5. Brake Discs
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2007, 10:55
