Thread: Fault Code P1109
    Jan 2010
    hertfordshire
    Default Fault Code P1109
    Hi, wondering if anyone had the same fault code on Diesel 55reg Vectra 150.
    Spanner came on then exhaust emission light .... local garage said fault code P1109 Secondary port throttle system ? Can't seem to find out how to fix it. Had new EGR valve 1 year ago ....
    Local garage said they need their electrician to look at it ?
    Any thoughts ...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is this the legendary swirl valve linkage failure?
    Oct 2007
    estonia
    faulty inlet manifold (loose swirl valve connectin bar) or the swirl valve actuator motor is at fault.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Take a look at this and the linked 'how to'
    http://www.vectra-c.com/forum/showthread.php?t=33645
    Jan 2010
    hertfordshire
    Thanks,
    Rung vauxhall and they said code related to Swirl vavle actuator .... will ring my local garage and see if he can do this fix .... or get a price for a new intake manifold ...
    thanks for your help.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Unless it's under warranty, you will be talking plenty of cash. the whole manifold will need to be replaced if the bar has detached, as the bar on it's own isn't available.
    I would look to see if it the acuator or the bar that is defective and get quotes based on that. Or DIY?
  1. P1109 Error Code
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:49
  2. 1.9 cdti 150 Fault: P1109 B SENSOR
    By SamT in forum Engine & Drivetrain
    Last Post: 22nd February 2012, 15:27
  3. Fault Code P1109
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:53
  4. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  5. P1109 fault code
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2009, 17:35
p1109 vectra c
p1109 vauxhall
SAAB P1109
p1109 error code opel
vectra c 1.9 cdti code p1109
p1109 saab
p1109 fault code
Opel DTC P1109-08
p1109 opel
Opel P1109
p1109 zafira b
p1109 fault code vectracar fault code p1109p1109 codeopel signum 1.9cdti 150ps p1109errore P1109-61Opel DTC P1109-61p1109 vauxhall fault codeopel vectra cproblem p 1109p1109 vauxhall vectravectra c p1109p1109 astra cdtip1109 errore obdwhat is code p1109 on obd readervauxhall vectra code p1109
