Results 1 to 2 of 2
Thread: Where is Ignition Wire located in the engine compartment?
    Regular Member the-converter's Avatar
    Australia
    Default Where is Ignition Wire located in the engine compartment?
    Does anyone know where I can locate the ignition wire in the engine compartment?
    I need to tap my LED DRL to the ignition wire so that it will turn on automatically when the ignition is live.
    I do not want to go through the firewall if it is possible.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    You will find a feed from the fusebox in the engine compartment
  1. Ignition wire
    Last Post: 4th May 2012, 18:15
  2. ignition wire colour??
    By Vectra SRi-direct 83 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2009, 19:42
  3. Ignition Switch Wire
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2008, 17:05
  4. Ignition Wire
    By James2k in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2008, 21:01
  5. Where is ignition wire?
    By danlat1415 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2006, 22:33
