Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Headlamp washers
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Default Headlamp washers
    Right ive got a new SRi bumper so i figured before it goes off to get sprayed id make my HID's 100% legal. ive got all the parts to fit the system exept mine doesnt have the actually wiring in the fuse box and the relays and such.
    my question is can i rig the high pressure pump for the headlamp washers up to the same pump that does the windscreen washers? Eg. Cut and solder them into each other so they both run off the same feed as it were.
    its going to be a hell of a lot cheaper than Tech2 ing it all and fiddling around in the fuse box.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Didnt thing headlamp washers needed tech2 ? thought it was just a bigger screenwash bottle with uprated pump and pipe work to bumper washers
    Irmscher Insignia CDTI 130
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    bigger bottle, high pressure pump all wireing in place, tech 2'd on and mine still doesn't work......
    Midlands Mod Shop - NFFC.
    apprently it does as if u have it all done propperly the washers will only come on the first time u spray for a certain amount of time then stop and wont come back on again for a set period..... its to save water i think.
    but to save £50 i think i can live with filling the washer tank up more often lol
    Question still stands can i run the two pumps off the same feed? i know obviously it will work and all be fine im just thinking of the CAN-Bus freeking out or the wires not being able to take the load.
    cambs
    Quote Originally Posted by ditchp View Post
    i got 2 pumps on mine
    one for the headlight washers and the normal one for front and rear screen and fully working.
    Trim : Get a
    Quote Originally Posted by mhvcbv View Post
    i have the 2 pump's also, all the kit is in correctly and even dean and his tech2 said it should be working but it's not....
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    ive retrofittet mine all works.. just followed the how2 and some tech2
    cambs
    they only work when headlights are on
    cambs
    its abit wierd as yours is a higher spec then mine.
    all fully working on an ls.
    did do all the wireing myself as it had none (not even the washer level sensor)
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    How much did it all cost Mark ?
  1. Fitting Aftermarket Headlamp Washers...
    By silestanix in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2011, 16:58
  2. Headlamp washers...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 12:58
  3. Facelift Headlamp washers
    By mucklestone in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2009, 17:33
  4. Headlamp washers
    By Jconnors in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 13:38
