Results 1 to 10 of 15
Thread: HID Flickering, solved?
    Jan 2010
    Lisburn
    Default HID Flickering, solved?
    Just about to install my HID's myself so have yet to find out if either it will trip the computer or have the lights flash, was browsing flea-bay and found these:
    http://cgi.ebay.co.uk/HID-DECODER-BU...item2304f598a3
    and
    http://cgi.ebay.co.uk/2x-HID-Kit-Com...item4a9ab941c0
    As you can see they resolve all issues with canbus systems etc...
    Anyone use these with good reports?
    I am actually contemplating holding off installing the xenons and perhaps order 1 off the 2 items above as a fail safe.
    Just get the Vec-C kit from HID's direct mate, comes with the cancellors and I had a year of troublefree operation on my full canbus Vectra...
    Jan 2010
    Lisburn
    Already had mine ordered unfortunately then decided to look at the how to's - as have installed them 3-4 times in cars that didnt have the "canbus" etc so the above seem to be a decent option if found flickering
    Regular Member i5aces's Avatar
    andover
    i have a set of them that came with my kit from hid direct there not fitted because i get no errors, i am getting flickering when the lights are off got better after i took them out, going to get the car tech 2 this "should" fix both bulb waring if there and flashing problems. i would say fit them first see if you have any problems if so you can have mine for p+p
    Jan 2010
    Lisburn
    Just fitted them in the rain and darkness - didnt have to remove bumper or headlamp units, tight fit on the drivers side but was all good, easily remove the lights, only footery connecting the wiring and seal at the same time
    No warning on the Computer, and no flickering, I either ordered a decent set or am a lucky git - well happy with the results!!
    Only question is, how do the guys align the lights for MOT on the vectra and is this affected by the xenons?
    Full Member paul.sessions's Avatar
    leighton buzzard
    they send these out with the hid direct set i got two sets and still not fixed the prob.
    Jan 2010
    Lisburn
    The dipped beam flickering would annoy me, but not getting that, only a warning message..which hopefully those will fix, if they dont fix them then wont really be that bothered as the worst case is you click okay to remove it
    However got Sidelight xenon effect LED's that are fantastic, nearly the same brightness as the lights lol, they flicker for about 10 seconds like a police light, looks pretty cool actually.
    Oct 2009
    Liverpool
    I got led sidelights yesterday, fitted them to my car and they flicker all the time, the only time they don't is when i have them turned on.
    They flicker everytime you do something to the car, whether it be open a door, lock the car, open the car.
    If you don't have the lights on when driving in daylight they will be flickering.
    Is there anything you can do to stop them from flickering?
    I think the reason they flicker is because when the car is doing something, the ecu is sending signals to check if all the bulbs are working and thats why you get the error on the dash board, could be wrong. Just wanting to know a way which you could stop it or would i have to go back to the boring bulbs :/
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Quote Originally Posted by morgan88 View Post
    I am going to use LED's but am going to wire my sidelights to the cigarette lighter circuit and leave the original ones taped up behind the headlightswill be done in the next few days
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    see its all this bull**** that makes me not buy any as it would just do my head in
  1. problem solved
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 18:51
  2. Rattle solved hopefully
    By satbeychap in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2008, 15:32
  3. MPG Confusion Solved!!
    By MattB in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2007, 13:50
  4. dilemma solved
    By spencer88 in forum General Chat
    Last Post: 5th September 2006, 02:44
vectra c hid flickering
vectra c hids keep flickering
vectra c hid kit
vectra headlight flicker
vectra xenon flicker
why do some hid lights flicker vectra c
