Results 1 to 10 of 11
Thread: Help & Advice Needed
    Jan 2010
    Portsmouth
    Default Help & Advice Needed
    Hi All,
    I have a 2004 Vectra DTi 2litre
    Has been a taxi and has done nearly 200k (pls take this into consideratino)
    It has what seems to be the common fault of the DMF (Flyweel)
    When the car is turned on and in neutral with the clutch let out, it sounds like there are tonnes of nuts and bolts crashing around the car, but when the clutch goes in and also when in gear and moving, the noise completely stops.
    Can someone confirm this seems to be the problem?
    I have taken it to a garage and they have said flywheel and you would need to replace clutch aswell (although it has not long had 1)
    The only thing bothering me is the fat that reading through most posts, that should be it, yet they are telling me that the gearbox will also need replacing and the overall cost is going to be £1000 +
    Can anyone local to me (Portsmouth) help by any chance, and do you think this is right?
    Liam
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    I thought that only the CDTI's had a DMF?
    IF I am right, then it sounds like the clutch release bearing....or maybe even Clutch and Gearbox.
    Have a couple of garages check it before getting it done.
    West
    The dti's also have a dmf, my mates taxi has had the clutch & dmf replaced... he didn't have to replace the gearbox
    Jan 2010
    Portsmouth
    it is a cdti i believe, sorry
    anyone local willing to have a look?
    anyone know of any local garages worth a try
    Cannot help with the garages or having a look but it probably is the dmf. If its recently had a clutch there is no reason it cannot be reused unless its been wrecked. Also I have never read of someone having to replace the gearbox when changing the dmf.
    hth
    Jan 2010
    Portsmouth
    so considering the sounds i am explaining you would agree that it is the dmf
    Jan 2010
    Portsmouth
    after speaking with Mr Clutch Portsmouth, (they haven't seen the car) when stating that the noise goes away when the clutch is depressed, and is there with the clutch not depressed, they say sounds like gearbox is knackered, but the ****** thing drives fine?
    Thats also very typical of the dmf.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    DTI's have DMF as well dreading the day i have to do mine i would take the car to a few places around your local area,it wont cost you a penny to get advise and a free estimate
    Irmscher Insignia CDTI 130
    Jan 2010
    Portsmouth
    Just to confirm, car is 2.0 DTi LS version
  1. Advice Needed
    By Doddy01 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 15:35
  2. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  3. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
  4. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  5. advice needed
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2008, 19:36
