Results 1 to 10 of 17
Thread: Best place to buy a Thermostat
    Regular Member jrwilshire2003's Avatar
    Bridgend
    Default Best place to buy a Thermostat
    Hi all. I have a 54 plate CDTi 150 Vectra and think the thermostat is on its way out as the temp gauge hardly moves and only goes up until 70 degrees when it does actually move. I was just wondering where the best (cheapest place) to buy a thermostat?
    Thanks for your help!!
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    common problem with most vecs
    my GSi only moves when im stood soon as i drive off it goes down to zero.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    mine too bud not seen it move for ages
    May 2008
    Tyneside
    I'd price one at the dealers first, sometimes they are pretty reasonable. Then compare with Autovaux who usually supply genuine or OEM parts bearing in mind they charge about £6 postage.
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Eurocarparts are a couple of quid cheaper than the stealers who arent bad on this one.
    Bridgend
    I also have the spanner through the sunroof light up on initial start-up and stays on for about a mile then isn't seen again. Does the thermostat flag this up or dohave another problem! <hehe>.
    Are you VXR Enough
    13 Post(s)
    spanner thru the sunroof???
    Bridgend
    In the rev counter. It lights up and and looks like the a spanner goes through the car. Seen people on here call it that thats all. Just wondered if the thermostat would flag this up
    Jul 2006
    Wolverhampton
    I never had this quite this bad when my stat went, but it could theoretically occur with time as the engine may overfuel due to the cold running temperature, resulting in more soot than normal which would build up in the inlet manifold due to the egr.
    I found mine heavily sooted up which had started to affect the swirl flaps and started to occasionaly bring on the EML.
    When I replaced the thermostat, I cleaned and modified the EGR as well as cleaning the inlet manifold as best as I could, boost sensor also cleaned and I have now done thousands of miles without any issues.
    No faults logged, no pending issue codes and EGR circuit all OK on diagnostics.
    Here's the link to how I replaced the thermostat.
    http://www.vectra-c.com/forum/showpo...6&postcount=14
    Sep 2009
    St Albans Herts
    i did mine before xmas, well worth doing, cheapest place i found was vauxhall but you don't need the paper gasket they sell you as therno body has o ring all in was 55 quid in 5 litres of vx coolant, you only need about 2.5 litrse though. remember bleed valve at front
  1. Anyone tried this place?
    By JM53 BEL in forum Styling
    Last Post: 26th January 2013, 21:30
  2. Best place for oil???
    By degsy1234 in forum Engine & Drivetrain
    Last Post: 24th January 2012, 16:34
  3. best place to get xp kit
    By jay6392 in forum Bodywork & Interior
    Last Post: 9th July 2011, 21:24
  4. 1.8 vvt Thermostat Price/ Place to buy ?
    By Happy Dave in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 20:13
  5. best place to look
    By blackbeauty in forum General Chat
    Last Post: 11th February 2007, 00:02
