Results 1 to 10 of 18
Thread: battery replacement
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    rolleyes battery replacement
    i might be replacing my battery on my signum 19cdti shortly and was looking for some advice,after replacement do you have to type a code in or anything like that to get everything working or is it just a straight swap? any advice would be much appreciated,
    cheers steve
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    What year is your car?
    Apr 2009
    CO DURHAM
    hi alan its a 56 plate
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Attach a battery charger to the terminals first, then didsconnect the battery,. That way you will keep all ur codes.
    Nov 2007
    weymouth, dorset
    Wont need any coding as the can bus head unit is only programmed to the car and doesnt need re coding after battery changing or going flat..
    Apr 2009
    CO DURHAM
    Quote Originally Posted by alanv6 View Post
    cheers alan thanks for your help
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    I changed mine the other day with no problems
    11 Post(s)
    You will however have to reprogramme the one touch elecy windows. Fully open, keep finger on open button for approx 5 seconds; then fully close and keep finger on closed button for approx 5 seconds. Repeat for other windows.
    As your car is a 56 plate, the battery should have loads of life left in it though. If it's faulty and the car has been serviced in accordance with VX's policy, and done less than 60,000 miles you should be able to claim on the 3 yr warranty. All VX batteries come with a 3 yr guarantee, even ones you buy over the parts counter.
    May 2007
    GLASGOW
    If it a 56 plate the 3yr warranty has ran out m8 it 2010!! :-)
    11 Post(s)
    Quote Originally Posted by LEW1S2006 View Post
    56 reg ran from 01st Sept 06 to 28th Feb 07.
    So in theory it could still have approx 5 weeks warranty left on it if it was registered on the 28th Feb.
  1. Battery Replacement - Anything to look out for
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2017, 13:57
  2. Car Battery replacement
    By Casper85 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 20:35
  3. Vectra C battery replacement problem
    By lilaclily in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2012, 19:17
  4. key fob battery replacement
    By cranny 27 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:22
  5. Battery Replacement???
    By B19CBB in forum Engine & Drivetrain
    Last Post: 21st May 2008, 19:32
