Thread: vectra 1.8 duelfuel 2003 knocking at rear
    Jan 2010
    croston lancashire
    Default vectra 1.8 duelfuel 2003 knocking at rear
    hi there had car a few days and when driving over pot holes and rough ground it knocks at the rear quite a lot its horrible. silent when on motorways and flat roads i cant see out ? it seems to be brake related cause when i press brake in it creaks and if i let go of pedal i get the knock but like something hanging and sort of knocking away . just cant see out under rear . not checked it out properly yet with all this dark nights and working. like i say its really smooth on flat road and motor way. its just over rough ground . weird .
    Jan 2010
    croston lancashire
    bump
    Derby
    Default Bump
    I have the same problem on my 03 3.2
    good job i do lots of motorway miles.
    can anyone help diagnose this?
    cheers
    alex
    Regular Member dave b's Avatar
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    Almost certainly the rear trailing arm links need replacing. They are banana-shaped linkbars with a rubber bush in either end, available via eBay or local motor factors fairly cheaply. Change the rear anti-roll bar bushes whilst you're under there too (also very cheap)
    That should solve your problem, it worked for me.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is easy to check for wear in these 'top link' bushes.
    Park with handbrake on and grasp the rear wheel at the top and wobble in / out. You will find it feels like and move likes the wheel bolts are loose if the top link bushes are shot.
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    Also, if you feel the car do a "side to side shimmy" at the rear while cornering and you hit a pothole or manhole cover, this would suggest the same fault.
  1. vectra 1.8 duelfuel 2003 sat nav question
    By sparks in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 00:54
  2. vectra 1.8 duelfuel 2003 whats this button
    By sparks in forum Engine & Drivetrain
    Last Post: 20th January 2010, 10:09
  3. vectra 1.8 duelfuel 2003 where is thermostat
    Last Post: 19th January 2010, 22:45
  4. vectra 1.8 duelfuel 2003 boot trouble
    By sparks in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 21:59
  5. Misfire under load. 2003 1.8 DuelFuel.
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 8th April 2009, 23:22
