Results 1 to 10 of 11
Thread: CDTI 150 'misfire'
    Bristol
    Vehicle : CDTI 150
    Default CDTI 150 'misfire'
    Hi,
    Whilst diesels dont misfire as such, thats how I would describe the symptom.
    Happens between 2000 and 2500 revs normally when accelerating gently; worse when going uphill. Otherwise car runs ok.
    Full service history, its an 05 pre-facelift with 79K. Has in last 6 months had 3rd inj wiring (& other 3 done), new EGR last month, boost sensor cleaned. Previously had new turbo (37K/2years ago) Pipe to turbo replaced, complete inlet manifold (40K/2.5 years ago).
    Shows no fault codes, OP Com shows swirl valves operating ok.
    Has also had a few good thrashes up n down the M54!!
    My next step will be to get the injectors tested unless anyone can point me in a different direction. Thanks
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    mine does the same but very random think it is injector problem but at 200 pound each dear guess
    Oct 2009
    Teesside
    Or £12 if you get the right part ;-)
    http://www.vectra-c.com/forum/showthread.php?t=73584
    Its caused by hot air going over the clip on injector three causing a bad connection - this modified clip gets around that problem!
    Mine had the same problems and I did this fix and not have a problem since, do a search its VERY common!
    Oct 2009
    Teesside
    the part number is an 8 at the end as well, not a nine as described!
    About a 20 min job if you DIY!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by robert_dale View Post
    He's said he's done the 3d injector wiring mod....
    durham
    mine has already had injector plugs changed as well
    Oct 2009
    Teesside
    Oops
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    is this description like a quick on/off snap!! jerk, then back to normal ?, i had this, lets say usually when driving between speed humps with normal acceleration, just get up to speed at around the revs described and a snappy jerk on/off. ????
    i can only say it has always!! been the egr! i have had this quite a few times, i has been a sticking or partly stuck valve every time, once i had a little carbon ball that was stopping the valve closing correctly.
    Quote Originally Posted by lesj View Post
    Hi,
    Bristol
    Vehicle : CDTI 150
    Hi,
    Fitted a brand new EGR last week, no difference.
    I think its injector related, gonna do a bit more invest tomorrow.
    Bristol
    Vehicle : CDTI 150
    Checked the EDC correction this morning, inj 4 reading +1.2 so overfueling.
    There is a sooty streak coming from inj 4 so I think its blowing back past the sealing washer.
    Will have to get new washer and remove inj to invest further.
    Will update again later
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  3. 1.9 CDTi MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 19th March 2009, 23:28
  4. Misfire on CDTI SRI 1.9
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 21:06
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
vectra cdti 150 misfire
vectra c misfiring
insignia diesel misfire
misfire on vauxhall vectra 2006 1.9cdti sri
vauxhall vectra c 1.9 cdti misfire
