You may have seen this before
Never seen that before... which door is it?
Drivers
Thats horrendous, obviously not prepared properly before spraying.
Ive not seen that before either
Back to the dealers and don't come from there until they agree to get it sorted!
.... Thats a new one .... of to the stealers !!
I did take it back to the dealer & they said that as I had only had the car for 2-3 months it would not be covered, Because I may have got the car cheap knowing it was like that, My reply after the swearing was that even if I had got the car for free it still has 6 years body cover from rust & that if they refussed to cover it I would go to the press as it on the weld that holds the side impact bar in place and I was sure they would be intrested. They then backed down and said it would be done as a good will gesture, I told them to stick the good will & I wanted it done under the corrosion warranty or not at all. They backed down. Just goes to show they will try to get out of anything . Just to let you know, There had never been any bodywork done I had checked it with a micron DFT gauge & it was within 3 microns all over the car.
Well done for sticking to your guns m8, if not you could have walked away and been left to pay for the repair
I thought I was going to have to pay as well. That would have cost a fair few pennies. They put a new door on in the end & took a deep scratch out of the back door for free for all the trouble I had been put through.
p.s when I say refussed I ment refused but I guess you all knew that.
