Results 1 to 10 of 11
Thread: 2.0 DTi spanner light
    Regular Member K18 JRT's Avatar
    Oct 2006
    exeter
    Default 2.0 DTi spanner light
    Probably a daft question but every time i go onto a dual carriage way/motorway normally at the very beginning as building speed my engine management light comes on and goes into limp mode.
    I know i need to get the codes read but meanwhile i'm trying work out if there is a common cause for this.
    The strange thing is i can drive the town around all day without a problem, even hard accelarating but soon's i join a carriage way/motorway i get the dreaded light.
    I cleaned the EGR valve in hope more than anything and there seems to be a small misfire at 2,250 revs.
    Any suggestions would be appreciated.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Did you also clean the boost sensor, that would be my first guess
    Oct 2006
    exeter
    Quote Originally Posted by steve View Post
    Erm no, but that's more to do with the fact i ain't got a clue what that is or where it is.
    Nottinghamshire
    As above, clean the boost pressure sensor and replace it if this doesn't work - about £50.
    Also check all of the small vacuum pipes (including the rubber ends) and large air pipes for any sort of holes and repair/replace them.
    Finally, check with your dealer to see if you car needs the free turbo recalibration recall.
    There's plenty of stuff on here about all of these issues as the "spanner light and limp home mode when accelerating at higher speeds" is a know DTi issue which the above are all causes of.
    Use the seach button at the top of the page to find out all you need to know - and feel free to ask about anything you can't find or are unsure about.
    Sort these out and then see if the misfire is still there...
    Oct 2006
    exeter
    Quote Originally Posted by James24 View Post
    Thanks to you both for your help, much appreciated.
    Oct 2006
    exeter
    Anyone know what the round thing is that has 2 vacuum pipes going into it, it's to the right of the radiator and the bigger rubber connecting pipe is split.
    Would that cause this problem?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    That is one of the vacuum actuattors you should have three in total on the dti engine and what they do is they stabalize your vacuum system , check all the connection,s for splits and that they have been connected up correctly , they should be marked on the top as to which way round they go,.( load going to the terminal diaphram,s )
    and still loving it
    Oct 2006
    exeter
    After replacing most of the vacuum pipes today it seems to have cured the problem, you wouldn't think something seeming so trivial could cause such a problem.
    Nottinghamshire
    Quote Originally Posted by K18 JRT View Post
    Good to know it's fixed- and that it was something trivial - and cheap!
    Jan 2010
    leicester
    hi all im having so many problems with my vectra 2.0 dti 2004 its untrue, 1, how can i check if my turbo was due a recall and 2, how would i know if thye vacuum actuattors are working? ive checked all pipes and conections all i found i split i the replaced pipe and all seemed good till i let of the revs then it just wouldnt run, to get me home i took thge vacuum pipe off that goes to the vacuum actuattor neear the turbo?! it ran like a pile of poo like it did with the split pipe but was able to drive? please help
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
