Hi do i need any adaptors for fitting onto vectra bumper, or will any set from ebay do as i think the bumper is more or less flat where they will go.
as above
and if you take the bumper off you will see four marks on the inside of the bumper for the sensors to go
Marks look like a rectangle with an x inside it. Everything you need to know on the position of the sensors is here - http://www.vectra-c.com/forum/showthread.php?t=100352
sorry know what to do 2 fit them, thanks for the info. What i want 2 know is will any sensor sit flush with vectra bumper or will there be a slight gap around them. These are the ones i am going to buy just curious because some sensors come with adaptors these ones dont.
http://cgi.ebay.co.uk/Reversing-Park...item4ce9ce95d6
hope this works
http://www.vectra-c.com/forum/attach...1&d=1192988011
cheers mate, so they sit out from bumper about 2mm, whats stopping them being flush.
I believe the flush mount ones have bits which fit behind the bumper while most of the aftermarket ones are designed to clip into the bumper.
