Thread: What is it hanging from the underside...
    Jan 2008
    Holbeach, Lincolnshire
    Default What is it hanging from the underside...
    of my 2.0 DTI?
    It is not the exhaust and it is from the centre of the vehicle when viewed from the side and rear, about two feet long
    It looks like aluminium with pre-formed holes: my notice was drawn to something being wrong when I start up I hear it rattle against the body work but it then stops.
    I would take a photograph but the camera is at home and I am not.
    It does not appear to effect the car in any way.
    I will try to get it on a ramp this weekend but if anyone has a clue?
    Don
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Heat shield ?
    Irmscher Insignia CDTI 130
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Yep i'd say heatshield, the holes which the bolts and washers fix into to fix it to the underside of the car become warn and eventually bigger than the washer so they fall away. I put a bigger washer on and job done!
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Mine was the same put bigger washer's on and bobs your uncle and fannys your aunt
    Wales, UK
    Yep, again - sounds like the heat shield.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Same here. however, I did almost rip mine off when I went through a ford a bit too fast obviously. It wrapped itself around the exhaust pipe. Took a bit to reform it and then secured with bigger washers (about 2" dia). It is secured by about 4 or 5 screws on each side of the tunnel.
    Jan 2008
    Default many thanks
    ...for the replies, chaps.
    As usual, great information on this site.
    Don
  1. Rubber hose on the underside of the airbox ?
    By VecPower in forum Engine & Drivetrain
    Last Post: 3rd February 2012, 13:56
  2. Wax oiled underside of vectra..........
    By Big Red in forum Bodywork & Interior
    Last Post: 21st January 2012, 18:16
  3. Creaking from Underside of car
    By Redviper in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2010, 20:29
  4. Pic Request: Underside of bonnet...
    By Leemarksmith in forum Bodywork & Interior
    Last Post: 17th January 2010, 22:48
  5. Rattle noise from rear of underside
    By Mike RB in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2009, 19:20
