Results 1 to 10 of 13
Thread: Reversing Kit for Vectra Estate
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Reversing Kit for Vectra Estate
    Has anyone fitted a Reversing kit to a Vectra Estate??
    All the posts I have seen so far show the Hatch.
    Removing the bumper on the Hatch looks fairly straight forward.
    Looking at the bumper on my estate, it doesn't look to easy to remove.
    Any ideas??
    member of the smoke patrol 230bhp+
    you dont have to take the bumper off
    if you look under your car at the rear you will find you do have the room to do that you have to.
    remember to fit a relay on the Reversing kit ,,,doing this will stop it bleeping all the time
    all you need to do is use all the wirring you have at your rear lights
    you do not need a a feed for the relay
    Jun 2006
    North West
    Thats good to know. I'll try and have a look underneath later.
    Where do you pass the wires through??
    Quote Originally Posted by Marky
    lift the spare wheel out
    look down and you will see a rubber gromit use that or get a stuffing gland it looks like this http://www.ghlucas.co.uk/products/pl...ble_glands.htm
    you will have seen them
    put it from in inside to the out so the nut is on the outer side of the car
    and there water tight
    you can put a fair few wires in them
    if you go to a electrical shop it will be about 1 pound hifi shop will be a lot more
    dont forget to use a relay
    you only need use the wires from your lights
    the relay will stop the bleep the light warning systum pulses the wire
    Jun 2006
    North West
    Cool.
    So I only need the wires from the lights? No need for any extra power cables?
    Hmm... Wonder if I now have the bottle to drill my bumper!!
    no need for extra cabling just what is at the lights
    find out what size hole you need there cutters you can buy
    http://www.lawson-his.co.uk/scripts/...20Drill%20Bits
    http://cgi.ebay.co.uk/11-Pce-Holesaw...QQcmdZViewItem
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Why is the relay so important? Just curious.
    Quote Originally Posted by Ben H
    the sensor will bleep
    the car send a voltage pulse for the light fault sensor the unit picks up the voltage and will begin powering up then powers down again
    the voltage sent to the lights for the fault sensor is to small for the relay to switch on
    so when you put it in gear its 12v at the relay,,,,it switch and the reversing sensor power up
    Jun 2006
    North West
    More great info, thanks Chris.
    Another question though. How do you get at the reversing lights (or any of the rear light cluster) on an Estate!
    I was looking at it the other day as I was thinking of getting the silver indicator bulbs but decided both the front and rear light units are not designed for bulb replacements and it might be easier to buy a new car if the bulbs go!!! Saves on the cost of skin grafts for the hands.
    take the trim out on the left hand side of the car it will make it a lot easyer to get to all you need to
  1. reversing camera estate
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2011, 19:33
  2. Vectra Estate Voted Top Used Estate in What Car 2010
    By keefy*2010 in forum General Chat
    Last Post: 22nd October 2010, 15:54
  3. Reversing sensors (estate)
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 13:04
