Thread: key fob fault
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default key fob fault
    As above
    Key fob will no longer open doors.Changed the battery quickly but still no go. Any ideas as when I open door manually the alarm sounds until key in ignition
    Mileage : 000
    Try putting the key in the ignition, Turn the ingnition on. But do not start the car ( dash light on), then press either the open or close buttons on the key fob. If the door buttons pop up and down, then you should be ok.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    I also have this problem with one of my keys. I do as above and after a few days I'm in the same position again!!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by 19CDTi View Post
    sounds like you need a new battery or either that or your keyfob contacts have come adrift
    Jul 2009
    Perth, Scotland
    I've changed the battery, and did it within the 1min timescale. I need to take it to VX I think and see if they will replace it under warranty
    Regular Member ballio's Avatar
    Jan 2010
    blackpool
    i have this problem too do we have an answer as yet ?
    Full Member paul.sessions's Avatar
    leighton buzzard
    i done this a while ago with her suzuki and found out that the brand new energizer battery i had bought from morrisons was flat had no power in at all!!, just a suggestion but try putting your old battery back in (unless its totally flat) and try that..
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
