Results 1 to 10 of 14
Thread: reversing sensors HELP PLEASE
    Regular Member SRIRob's Avatar
    Jan 2010
    Essex
    Default reversing sensors HELP PLEASE
    Going to fit my reversing sensors tomorrow could anyone please post a picture of the location of theres doesnt have to be exact measurements just a pic of where there fitted thanks Rob
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Jan 2010
    Essex
    Thanks Lee thats exactly what I needed, well done that man
    Slough
    76 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    rob are you fitting a aftermarket kit on .khalid
    Jan 2010
    Essex
    Quote Originally Posted by happypostie View Post
    Yes mate Ebay specials allready sprayed and ready to go, Why do you ask ??
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by SRIRob View Post
    There are proper markings on the inside of the bumper mate, it only takes 2 mins to get it off and all the marking are molded into the plastic bumper skin.
    Dunstable
    should look like a rectangle box with an x in the middle of it. Just drill in the middle of the x and it'll be exactly in the right place as the oem sensors! No measuring required...as long as they are already on your bumper!
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Quote Originally Posted by Ademusic View Post
    And the kit should come with the proper hole cutter drill bit too.
    Paul.
    Snowman, you got your ears on?
    Slough
    76 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    ive got a aftermarket one and as said the markings are on the inside off the bumper.khalid
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    This is what I did for the rears without taking off the rear bumper for reason previously posted using the post on rear sensor positions (& not meant to be a 'HOW 2 ')....Cheers
    'Flexible ruler...
    Positions marked on masking tape and drilled with a small pilot hole
    Masking tape removed and small blanking grommets fitted to check positions before drilling the holes proper...
    Small pilot holes were covered with 50mm masking tape, Main holes drilled with 21mm hole cutter provided with the 6 sensor Gadgetman Kit I bought & 20mm black blanking grommets fitted to 'mimic the sensors..
    Blanking gommets then colour coded to mimic the black sensors which I colour coded Lightning Silver to see what the colour match would be......
    Sensor controller which can take it's supply from the reversing light feed(& change-over relay - my method of control with test lead to prove everything works) mounted on storage cavity on LHS of boot where optional first aid kit would be mounted)....
    Buzzer...
    Colour coded Sensors Fitted
    Hope it is useful.....
  1. reversing sensors
    By redo in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 19:27
  2. reversing sensors
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 21:10
  3. Reversing sensors
    By d16wal in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 00:48
  4. which reversing sensors please?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 21:48
  5. Reversing sensors.
    By alb in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2006, 15:51
