Thread: vectra 1.8 duelfuel 2003 whats this button
    Jan 2010
    croston lancashire
    Default vectra 1.8 duelfuel 2003 whats this button
    on my keyfob i have a picture of a suitcase i press it and the hazrds just flick once nothing happens then and it does that all the time if you press it. the button on the drivers door handle with the pic of a car looks for the boot i press it and a beep jus comes from the cluster panel again nothing changes. i have to open boot with my key as pressing the open button twice dont open it and neither of above buttons open it . does anyone know what they do and why they not doing it for me cheers
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    It unlocks the boot.
    Jan 2010
    croston lancashire
    well its not doing it ? is there something i can check what will cause it not to work . cheers
    Lock the car, push the button and try to open the boot. If it won't open then its possible that the key slot is in the wrong position - if there is one. (boot is unlocked with that button, it should also put the number plate lights on to indicate the boot is unlocked)
    If that fails, Read the manual!
    Jan 2010
    croston lancashire
    ive tried the different ways on the key barrel vertical and horizontal. will try again . and if all fails am fooked as ive no manual ?
    So how do you open the boot now? From the button inside on the door?
    When you press it do the number plate lights come on?
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    from previous experience on my vec b which had a barrel. there is a plastic mechanism inside that fails & doesent pop the the lock. aint to sure as its a vec c. (i thought all the vec c's didnt have a barrel on the boot)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It won't 'pop' the boot. You still have to press the button on the boot lid.
  1. vectra 1.8 duelfuel 2003 knocking at rear
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 00:39
  2. vectra 1.8 duelfuel 2003 sat nav question
    By sparks in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 00:54
  3. vectra 1.8 duelfuel 2003 where is thermostat
    By sparks in forum Engine & Drivetrain
    Last Post: 19th January 2010, 22:45
  4. vectra 1.8 duelfuel 2003 boot trouble
    By sparks in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 21:59
  5. Misfire under load. 2003 1.8 DuelFuel.
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 8th April 2009, 23:22
