Results 1 to 10 of 16
Thread: washer jets
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default washer jets
    anyone know what could be wrong with my washer jets i can hear the pump going and they spray once only about 1 inch every now and then whwn i try and use them i thought it was kind of strange they all would stop at the same time any help would be great
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    could be the filter in the washer tank needs cleaning out bud
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    defo the filter..
    Trim : SRI
    Mileage : 46000
    i did not even know there was a filter in the washer tank thanks i will have a look tomorrow
    Nottinghamshire
    There's quite a few posts on here with inforrmation on how to clean the washer pump filter.
    Use the search function at the top right and type in something like 'clean washer filter' and have a read through the likely-looking entries in the results.
    Sheffield
    I had the same last week, it turned out to be the small plastic elbows that come out of your washer pump behind the wheel arch. I removed them and discovered that each elbow has a very small non return rubber valve like a dummy, that had wedged too far in, I used a needle and removed the tiny washer that holds it in and then removed the dummy and re inserted. Works like new again.
    Hope it is something as simple as that.
    Nottinghamshire
    Quote Originally Posted by C@rlos View Post
    My washers are on a go-slow again, so it looks like I'll be checking the pump filter again this weekend. I'd not heard of this problem with the elbows before, so I'll give that a check as well while I'm under there.
    Sheffield
    I would give it a go first, I faffed around with everything else first and it was the last thing I checked, easy to take off and blow through to see if there is any resistance.
    Trim : SRI
    Mileage : 46000
    ok so i now have the washer pump out when you blow through the black end it comes out but nothing from the white end any ideas what is wrong
    Trim : SRI
    Mileage : 46000
    i have just had the washer jets off and there is no water getting to them helllllppppppp meeeeeeee mot is getting closer
  1. Washer Jets
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 17:20
  2. Washer Jets
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 09:06
  3. Are there any better washer jets out there..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:45
  4. Washer jets....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 17:59
