Thread: 2.2 Direct going into limp mode
    Regular Member steviemac74's Avatar
    Jan 2008
    Livingston
    Default 2.2 Direct going into limp mode
    My brother-in-law has got a 05 plate 2.2 direct petrol vectra which went into 'limp mode' today,spanner light came on also but no eml,managed to nurse it home,i changed the fuel filter as it felt like a fuel starvation problem,no change.Started and stopped it a few times which eventually got the spanner light out,car now revs but only if you gradually press the throttle,if you stick the foot down it won't rev.Took it a run again it's fine until 3000 rpm then it holds back until 4000 rpm then goes again.
    There is no misfire at all,i was thinking egr valve or air flow meter.
    Any suggestions guys??
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    High pressure fuel pump and regulator fault sounds like... I replace the pair usually for this fault..
    Regular Member ballan22direct's Avatar
    isle of lewis
    I dread this. Every time I feel a judder I prepare for the worst. Hope it sorted out soon though.
    Jan 2008
    Livingston
    Oh dear,sounds expensive!!
  1. Vec C 2.2 DTi going into limp mode
    By krazylegz in forum Engine & Drivetrain
    Last Post: 21st February 2012, 20:02
  2. 2.2 direct limp home mode
    By noel.nev in forum Engine & Drivetrain
    Last Post: 16th April 2010, 14:43
  3. 04 2.2 direct z22yh limp home mode
    By Phil2511 in forum Engine & Drivetrain
    Last Post: 25th February 2010, 19:05
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. Vectra 2.2SRI Direct Misfire/Limp Mode
    By craig123 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2009, 22:28
vectra c 2.2 direct limp mode
vauxhall zafira 2.2 wont rev
vauxhall 2.2 wont rev over 3000.revs
zafira 2.2 petrol limp home when high revs
vectra wint go over 3000 rpm
vauxhall vectra 2.2 petrol limp mode
vectra c going into limp mode when revved
vectra c petrol car spanner light on and wont rev past 4000
