Results 1 to 10 of 26
Thread: Pros and cons of an automatic?
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Pros and cons of an automatic?
    What are the pros and cons of an automatic 1.9 CDTi over a manual? I've seen a really nice auto vec with snow flakes and a vxr body kit and i'm thinkin' of buyin' it. Thanks for any feed back.
    Preston Area
    well I drive a lot in london, stop start stop start and all that... wouldn't give a xxxx for a manual! been on auto for years now and if you know what you're doing with them, you can have just as much fun burning boy racers off the lights
    May 2008
    Tyneside
    Downsides are less consumption, expensive repairs and not too good in ice and snow.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    but auto's are expensive when they go wrong which they do quite often
    Regular Member signum03's Avatar
    worthing
    never had any probs with my auto and i love it, would never buy a manual again!
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    They go wrong for 2 main reasons:
    1. Improper maintenance.
    2. Improper driving.
    If you decide to go for an auto, be sure to check at least 2 things regarding the gearbox:
    1. Car's service book, to see if the gearbox oil was changed on time (every 60.000 Km)
    2. Take a tour with the car and use all gears from 1 to 6, from 6 to 5 and the Reverse one. NOT in manual position, but in automatic.
    My car has a slight problem due to oil not being changed until 120.000 Km: when I cruise in 5th gear (2200-2500 rpm) and I hit the accelerator hard, I get a really bad jerk when it goes from 5th to 4th.
    Make sure you check all gears this way. Cruise at 1800-2000 rpm in every gear and press hard on the accelerator.
    Although it's quite expensive to repair it, it's not cheaper to repair a manual either. People who say automatic gears are more expensive to repair if they go wrong, I'm pretty sure they never thought about the costs of a faulty dual mass flywheel (DMF).
    Liverpool, UK
    Quote Originally Posted by Lao View Post
    Thanks for the heads up mate, if I go for it I'll be sure to check these things.
    It really is a smart looking car If I can manage to get it and its in good nick I'll be a very happy boy.
    Regular Member badback's Avatar
    Runcorn
    I've had my auto for 3 years and not had a problem with it, average 40 mpg. I love it, wouldn't go back to a manual.
    Liverpool, UK
    Quote Originally Posted by badback View Post
    what does it get on the motor way??
    Runcorn
    40 mpg is the best I can get out of it. If it was just motorways it would be slightly higher, I never hammer it though, maybe boot it up a slip road every now and again just to clear it's throat.
  1. EGR pros and cons
    By faz123 in forum Engine & Drivetrain
    Last Post: 7th November 2012, 15:40
  2. Pros and cons of mapping.
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 08:16
  3. 255 or 280. Pros and cons.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 18:59
  4. Remapping Pros and Cons
    By Grovercus1969 in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2010, 02:25
  5. Should I fit a CR1 - what are the pros + cons
    By ballogie in forum Diesel Engine related
    Last Post: 19th January 2007, 19:57
