Results 1 to 10 of 15
Thread: z20net - ticking noise from engine when warm
    Sep 2009
    Slovenia
    Default z20net - ticking noise from engine when warm
    Hello,
    Got my 2007 2.0t Vectra with 40K miles on the clock and it is a nice ride, but I noticed some strange noise, only when engine is warm.
    I drove over 60 miles every day and when I stop and leave the car in neutral I can hear tapping/ticking noise from the right side of engine (near the tyre) if I look the car from the front. If I go in a car and press clutch or just slightly press on gas pedal, noise disappears and then come back again when idling.
    Pressing clutch several times and noise is gone for some time...it's like something gets in resonance or two small steel materials will tapping
    BTW: I noticed that service fill oil over the maximum indicator...is this somehow related?
    Is this something to worry about?
    Thank you.
    Full Member Big Sig's Avatar
    Could be the dual mass flywheel about to expire.
    Sep 2009
    Slovenia
    hmm I hope this is not the issue
    Doesn't DMF problem behave just opposite? If there will be DMF problem noises would start when i press on clutch pedal or am I wrong.
    This noise is present only when car is idling and engine is warm and I am not touching any pedal.
    Oct 2009
    bolton
    nowt to worry about bud i have had two of these cars and they both occasionally do this my current one only done 33000 miles and ticks sometimes stop listning to it and enjoy
    Sep 2009
    Slovenia
    I guess you are right...I am a bit paranoid
    But some little ticking at start can change to big-bum at the end...that's why I am asking
    Thanks...so no more listening and ignore. done!
    Quote Originally Posted by buggy View Post
    It could be the dmf as they go quiet when you press the clutch half way down.
    Could also just be the tappets making a small amount of noise
    Sep 2009
    Slovenia
    I recorded this idling noise. I also step on clutch pedal some times, then noise is not present anymore.
    http://www.shrani.si/?19/dL/V2tkplC/vectranoise.wmv
    So this is DMF then? But at 40K miles this is strange...is this some factory fault material or is the driving style what caused this?
    Northampton, UK
    Mine ticks when you turn the engine off after I've given it some beans at rounderbouts etc... until I learnt to drive a little easier near home.
    Nottinghamshire
    If the oil is up to or over the MAX line on the dipstick, I'd get that sorted first. Garages always did that with my car before I started servicing it myself. I fill it to somewhere about two-thirds of the way from MIN to MAX and it definitely runs and performs better like that than with the oil level right on MAX or even above it.
    If you're lucky this may be causing the oil pressure to be a bit on the high side and this may in turn cause the ticking noise, especially if it didn't do it before the last oil change when it was overfilled.
    It's a quick and easy thing to rule it out first before looking at more complicated/serious/expensive things...
    Quote Originally Posted by n_hudson View Post
    Thats the heat, you need to make sure the turbo has cooled down before you switch it off or it can burn the oil left in the hot turbo causing it to fail eventually.
  1. Ticking noise from rear of engine
    By steveyd83 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 21:57
  2. Ticking noise from engine??
    By Gracey in forum Engine & Drivetrain
    Last Post: 31st January 2012, 00:23
  3. ticking noise from engine
    By johnny ni in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 23:16
  4. Vectra C 1.8 SRI engine ticking noise
    By peternotails in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:25
  5. Ticking noise from engine... more so near the injectors
    By JonR in forum Engine & Drivetrain
    Last Post: 28th January 2008, 20:54
vectra c ticking from engine
z20net engine noises
vectra z20net tapping noise from engine
z20net noisy engine
vectra c 1.8 petrol injectors loud ticking
vectra c Z20net tapping noise
slight tick tick sound from engine vectra c
vectra c clicking tapping from engine
z20net clicking noise on idle
vectra c tapping noise on idle
z20net engine loud rattle noise
vectra c knock when its hot out
