Thread: Brake pads, Change time
    Regular Member Readster's Avatar
    Plymouth
    Default Brake pads, Change time
    I have had enough of the squeal caused by 'cheap' brake pads.
    Before I get VX/GM ones are there any other makes that could be an alternative?
    Mine is a standard diesel estate that is used to haul the family & dogs.
    No racing for me
    John
    Regular Member cphaza's Avatar
    Hertfordshire
    I change probobley 15 sets of pads a week and we use Apec brakes here. Never have a problem, but no matter what manufacturer you use, if your disc surface is uneven you may well get squeel due to the friction surface not being in full contact with the pad. In this instance, i get some sandpaper and give the disks a flipin good 'scouring' to make them as flat as possible. Do it on your pads as well and you should be ok. Dont forget the dabs of copper ease so the pads slide properley on the carrier.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have used Mintex pads on various cars in the past and they are good
    Plymouth
    Quote Originally Posted by cphaza View Post
    Thanks cphaza, I'll try that with the pads. I have copper eased everything and there no is no binding at all.
    This is the first time I have had this issue as before, change the pads/discs, bed them in and that's it...
    Plymouth
    Quote Originally Posted by ANDY W View Post
    Thanks Andy
    Leicester
    Just go for VX OEM discs and pads, on trade club they are only about £58 + VAT for the disc/pad kit.
    VX OEM stuff is the best for every day use.
    Hertfordshire
    let vaux set i used had Pagid part numbers stammped on them....
    What manufacturer did you fit in the first place mate?
    Plymouth
    I got them from autovaux. There are german ( I think) but not a brand name I recognise. Passed the MOT though..
    Regular Member david.aka.judas's Avatar
    Suffolk
    Jun 2007
    Black Country
    I hated the genuine VX pads and I'm now using red stuff pads which are superb, if your less than 200 bhp then green stuff should be fine, not had a single squeal since fitted and bedded down in less than 100 miles, whereas the VX ones never bedded in
  1. Tools needed to change brake pads ?
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 12:30
  2. Want to change brake pads and discs
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 19th September 2008, 17:53
  3. What tools will I need to change brake pads
    Last Post: 24th June 2008, 20:30
  4. Change of brake pads
    By saulfreak in forum Suspension, Wheels & Brakes
    Last Post: 22nd September 2006, 17:05
