Thread: Vectra CDTI150 ECU Remapping
    Jan 2010
    Leeds
    rolleyes Vectra CDTI150 ECU Remapping
    Hi,
    Has anyone here had any experience with ECU Remapping on a 2008 Vectra CDTI150 .
    I'm looking at getting it done but feel confused.com and am looking for the do's & doníts and any referrals.
    NEWCASTLE
    av had a stage 2 on mine roughly 197 to 204 bhp mate
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Alot of peeps on here use the BSR ppc and get good results.
    West
    Quote Originally Posted by Stuarty View Post
    That would be my preferred chooice
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I have the BSR PPC & it gives a good boost in power (from 150 to approx 185), is user friendly & can be installed or removed from the CPU in less than 2 minutes incl removing the Ashtray - I always remove it before I take it in for a service
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by Ian S100 View Post
    how much are these ,
    where do they go and i persume they can be done by yourself
    cheers
    Mar 2007
    Southport
    Quote Originally Posted by myelite150 View Post
    cheers
    BSR PPC
    http://www.bsruk.co.uk/tuning_ppc.htm
    http://www.bsruk.co.uk/tuning_produc...ctra&e=1.9CDTI
    Ballpark figure is about £500
    As you will see from the links The PPC comes as a programming box & lead - to programme (remap) the car, remove the ashtray insert, attach one end of the lead to the socket underneath the ashtray & the other end to the PPC box - follow the instructions on the PPC screen & 2 minutes later you have a remapped car - to remove the map do the same again & 2 minutes later it's back to standard & undetectable. You can do this as often as you want.
    IT's not the cheepest solution but in my opinion it is the best
    Hope this helps
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Had the BSR PPC for a bit over a year or so. Simple to use. I always take the remap off when it's srviced just in case it causes the garage to get something wrong (and also I don't want them quibbling about the warranty if anything needs fixing!!!!). Pulls like a train but is still very driveable. The downside is that it is probably the most expensive option.
  1. Vectra Elite CDTI150
    By Matt_Bankier in forum Vehicle Diaries
    Last Post: 17th September 2013, 23:03
  2. Vectra c 2.2 Dti remapping
    By Jez1516 in forum Diesel Engine related
    Last Post: 22nd June 2012, 21:17
  3. Vectra 1.9 cdti150 ECU location...
    By toadie83 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 14:59
  4. J** OGY vectra cdti150 sri black
    By vectra666 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 19th January 2009, 22:10
how to take ecu of vectra cdti150
