Results 1 to 10 of 16
Thread: what the most problems with these
    Regular Member sri adi's Avatar
    Jan 2010
    ireland
    Default what the most problems with these
    Hi guys Im new on here. Im buying a vectra c 2.2 sri dti sometime this week, just wanting to see if anyone had had any major problems with them? Are they reliable and what kind of mpg will they return?
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    the 2.2dti is a good engine if looked after mate , i had some electrical problems when i got mine , that was the car not the engine , and the only problem i have had is the crank pulley went , but again something relatively quick to sort out and the part is £200 from vaux.
    MPG - at the moment im doing a lot of town driving and i have a heavy foot so im getting 35-38 mpg , but the other day i did a motorway journey and i was averaging 55mpg.
    reliability - apart from the crank pulley nothing yet , i also find putting shell v power in the car made a huge difference to general driving and performance so i put that in all the time
    only thing that bugs me is sometimes when u change into 5th to soon it goes into limp home mode , vauxhall apparently did a recall for this which my car had and it still does it so i just make sure i never go into 5th to early
    and ive done 12 thousand miles in the 7 months ive had her
    Jan 2010
    ireland
    Quote Originally Posted by shaun260589 View Post
    hi shaun thanks for the input really helpfull??so is this with all 02 where it gos into limp mode
    Nottinghamshire
    Shaun,
    Providing your air pipes and vacuum pipes are all OK, the limp home mode in 5th gear is likely to be the boost pressure sensor needs cleaning or replacing (if the cleaning doesn't work replace it) or the turbo recalibration (your dealer can tell you if this applies to your car).
    In my case, it was the boost pressure sensor - cleaning didn't work so I replaced it early last year and haven't had a single 'limp home' mode since. Getting the fault code read may help - mine was a stored code so the light didn't have to be one when the Tech2 was connected. The fault was something like 'boost pressure out of range'.
    I had the turbo recalibration done just before Christmas because the dealer the car went to for some other work found it was outstanding.
    hull
    my mate has a 2.2dti, crank pulley cost him 90quid diy. usual suspension probs. turbo failure at 40k. now done 200k and still strong.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    only probs here so far springs 03 plate 40K
    good car i get 36-38 motorway bout 55
    Regular Member i5aces's Avatar
    andover
    i had one of these for 18 months before i got my v6, it was that good that my brother bought it off me, the only problem i had in all that time was limp home caused by a crack in one of the vacum pipes, appart from that and general service parts and 2 tyres didnt cost me a penny, great mpg especially on the motorway, even tho mine has 114k when i sold it, it still felt like a car with half that, i would recomend one to anyone, cant sing its prasies enough, hth
    Jun 2009
    Newcastle
    Quote Originally Posted by James24 View Post
    Shaun,
    ill have a look into that cheers mate
    apart from that love it , its turning out to be a great first car( was insured on mums clio for 2 years) for a high mileage driver
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Dont be afraid of getting a DTi
    Its a solid engine, and for what Ive experienced myself, and what others here also have stated, there are a few "glimps" to look for, just as you find on other engines:
    • Limp home mode, most often caused by clogged EGR and inlet manifold
    • Cracks in air intake hoses, vakuum lines, diesel return lines
    • Turbo is a bit sensitive for oil quality / change
    • Crank shaft pulley
    Most of this is easy to avoid or fix yourself for low costs.
    Good luck with buying
    Regular Member Stuarty's Avatar
    Aberdeenshire
    My mother has a 2.2dti 04 sxi estate shes had alot of bother with it cutting out and going into limp mode so far it has had the vacum hoses replaced and the injector seals done its still not quite right if left facing nose up on a gradient it will start for five seconds or so then it will cut out and take a good while of turning it over to start up again.Apart from that it has been a good motor its a bit slow though compared to the cdti 150.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
