Thread: How to install a LED DRL with the module?
    Regular Member the-converter's Avatar
    Australia
    confused How to install a LED DRL with the module?
    I hope this is going to work for me.
    I bought a set of LED light with the module.
    The module will control to turn on the LED DRL automatic when the ignition is turn on and will control to turn off the LED DRL automatic when the headlight is turn on.
    Here is the installation instruction from the box.
    1. Red wire to +12V battery
    2. Black wire to Ground
    3. White wire to LED light
    4. Blue wire require signal input from ignition
    5. Yellow wire require signal from headlight low beam
    Here are my questions:
    a. When I connect the red wire to positive terminal of the battery, do I have to disconnect the negative terminal first for safety reasons. At the same time I do not want to upset my security system on board. Any ideas?
    b. I am ok with step 2 & 3. I believe step 2 should be the last step to do for this DRL installation. Am I correct?
    c. Step 4 - I was thinking to tap the wire to one of the fuse located in the engine bay such as fuse no.5 the windscreen washer system.
    d. Step 5 - same as above tap the wire to the headlights fuse no.8 from the engine bay fuse box.
    I found this fuse tap from my local electronics shop which I going to use for step 4 & 5.
    Any comments is welcome.
    Thanks in advance.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I would install in the order 3, 4, 5, 2, 1 so you won’t need to disconnect pos or neg for safety
    Step 4 – seems ok but does that thing replace the fuse with another fuse or is it designed for empty slots?
    Step 5 – the fuse is probably before the light switch so unlikely to work, just scotchlok into one of the low beam feeds & hope it doesn’t affect the bulb failure system, I doubt it will as you're only adding a very small additional load.
    Connect 1 to the battery but make sure you use an suitable inline fuse as close to the battery as possible
    Australia
    Thanks for your inputs.
    The fuse is designed to replace the existing fuse. I bought the right amp to replace the existing one.
    I was thinking to run a trial on my jumper starter instead of on my car battery without disconnecting the car battery.
    I am not sure having two power sources at the same time will cause any problems.
    Mar 2007
    Southport
    The module will be a relay - the inputs from 4 + 5 will just be triggers with the main power supplied by 1 so I doubt you will get anything if the battery feed isn't connected
    Australia
    The jumper starter will be the main power supplied by connecting 1 to +ve terminal and 2 to -ve terminal as the replacement of the car battery.
    If the trial run is working then I only connect 1 to the car battery and 2 to the car body for ground.
    Australia
    Can anyone please confirm by connecting red and black wire to the jumper starter for power source, blue and yellow wire to the fuse from the engine bay fuse box and white wire to the led lights will cause any problems to my car system?
    I just wanted to test my method is working or not before connecting red and black wire to my car battery.
    Thanks.
    Australia
    Finally, I did it.
    Here are my steps: 3,4,5,1&2.
    For step 4, I replaced the fuse no.4 air conditioning & climate control with the fuse I mentioned before to get the ignition live.
    For step 5, what I proposed doesn't work. You are right. So I soldered the yellow wire to the headlight yellow wire from the socket.
    The rest of the steps are straight forward.
    I show you guys some pictures.
    Quote Originally Posted by Ian S100 View Post
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    What do they look like on?
    How have you got the chrome on the lower grill and fog surrounds...
    Mar 2007
    Southport
    Well done!!
    Is your grill standard in Oz because it looks like an Opel grill with Vx badge
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Its a Holden badge mate Germany is opel we are vauxhall and aussie's are Holden
    Irmscher Insignia CDTI 130
  1. Can someone tell me where the BCM module is?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 16:41
  2. cim module anyone
    By triplecrown31 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2012, 22:54
  3. CIM Module
    By phil79 in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2008, 11:32
  4. CIM module
    By rayvo-gsi in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2007, 02:12
vectra c drl install
vectra c fog led drl mod
