Results 1 to 10 of 23
Thread: Fitted my VXR 345's BUT..
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Default Fitted my VXR 345's BUT..
    Went to work on saturday morning as planned..cleaned up calipers and discs etc.. fitted new set up.. went to bleed up and no pedal.. first depression nothing second depression were getting a pedal.. very like their was air in the system.
    I then procedded to pressure bleed..no air present but still no pedal.. my first thought was the master had crapped its self.. so i put the standard set up back on and it bled perfect.so thats fine..
    Their were no leaks present..no pressure lost in the system and teny were bled in sequence to no avail..
    I have spoken toanother member who had a similair problem with 314's.. a new master cured his and a good bleed..
    Is my master not man enough for the 345's..
    Some folk will reply take it for a drive it will get better...not a chance on this one..i know when a pedal is to the floor or gonna get better
    my cars a 1.8 i will look into a different master if i have too but shouldnt think i would have to go down that route.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    not heard that prob thought a master cyl was the same across the range. maybe like you said just damaged a seal
    Quote Originally Posted by mattv6diesel View Post
    I did this that to mate..i wouldnt think a seal is damaged tbh mate..i put the original brakes back on and it bled no problem and the pedal is fantastic..
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by Dose View Post
    maybe thier is a diffence and your master cly just can't get all the fluid it needs to, could try doing one corner at a time
    Its getting the fluid just not building the pressure.. tahts my next port of call.. gonna rebuild the calipers in the mean time i think
    What were yours to start with mate? I fitted my VXR's on mine with no issues but I had the 314's to start - this may or may not have made a difference with the master cylinder...
    Duncan fitted his on top of his 302's, and again had no issues...
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Silly question, the calipers werent wrong handed were they? if they were the bleed nipple would be in the wrong position and you would have trapped air you cannot bleed out...?
    Northampton, UK
    I'm having a similar problem, but with just one caliper. They caliper retracts fine when the bleed nipple is loose, but when I finish fitting and all looks fine, the piston decides to stay out pushing into the disc. I'm thinking a refurb or just a new seal kit will sort my problems. I've gone from 302's up. The brakes do feel a little more spongy but they are a lot sharper. (When they worked LOL) so I'm back with my 302's at the moment. LOL
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Quote Originally Posted by plasma View Post
    just what i thought mate fitted a set to his and had the nipple wasnt at the top . swopped them over and bingo it bled.
    i have a 1.8 and fitted 314 mm a yr ago when the saab agents were selling them of in milton keynes and had no probs bleedeing . yes did have crap brakes till they bedded in. just got some vxr rear calipers and thats the next on my list to do
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    thats what im thinkin
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. Hid fitted
    Last Post: 29th December 2010, 19:16
  3. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  4. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
  5. just fitted cr1 OMG!
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 16:08
