Thread: CD30 and Ipods
    Jan 2010
    Durham
    Default CD30 and Ipods
    Hi everyone. I happened on your forum when researching the apparently age-old-problem of whether or not I could run an ipod through my 57 plate Vectra CD30 stereo (no aux in). Your forums document this problem quite well and the answer is basically NO - unless I use an FM Transmitter (mucho interference) or FM Modulator (mixed reports).
    I thought I would get in touch however, to point out something I have since found on the internet which seems to get around this problem. It's called an 'iO Connect' and is basically a seperate amplifier which hijacks your speakers (or Mutes them) whenever you connect an auxilliary device. They are available (even for Vauxhalls!!!) through www.nexia.co.uk (amongst others) with a wiring kit together with basic Ipod connecters starting at about £65 all in. Has anyone tried or got one of these and if so are they up to much??
    Cheers. Dave.
    Jan 2010
    Durham
    Sorry, it's actually NEXXIA (two XXs) and the link is halfway down on the http://www.nexxia.co.uk/Car_Audio/iO_Play.htm page (orange box thingy).
    Dave
    Jan 2010
    Alps
    I too would be very interested in hearing about this iO Connect box.
    Your description sounds bang on.
    I've also identified a couple of other alternatives:
    The iConnect from Connnects2
    https://www.connects2.com/Instructio...ctVauxhall.pdf
    £40-£50
    The Ice>Link One from Dension
    http://dension.com/index.php?pageID=175
    About €100
    Has anyone installed any of these 3 adapters?
    I like the look of the iConnect but I'm concerned that:
    a. my CD30 doesn't have a AUX input
    b. even if it has, how do I select it? does the audio system automatically switch over?
    I'm cautiously optimistic as I've noticed in the audio menu an entry called "Ext"
    Any ideas?
    Regular Member russ1969's Avatar
    Worthing
    I've got the parrot MKi9200 in mine which does the bluetooth streaming if needed, handsfree calling with voice activation and can also be hard wired to ipod or iphone a really good piece of kit
    Regular Member gaz4d's Avatar
    Glasgow
    Quote Originally Posted by russ1969 View Post
    Same here.
    It gives full ipod use via separate steering wheel controls.
    Also allows you to use: flash-drives / SD cards to store and play your music.
    ps. smart removable screen also.
    Newport
    How does this parrot device connect to the car speakers? Sounds great!!
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Quote Originally Posted by The Goatreich View Post
    It mutes the head unit and uses a built in amp to give volume to the speakers.
    Best option IMO, the above connects2 adaptor will only work if you have Aux in option any way,
    Newport
    So you physically have to connect it to your existing head unit? Is this an easy job? Sorry to thread hijack by the way, you just asked exactly the same question as I was going to.
    Glasgow
    The following thread gives you an idea of how the Parrot MKI9200 set-up looks.
    http://www.vectra-c.com/forum/showth...highlight=9200
    HTH
    Newport
    Great, thanks.
  1. iPods - Wheres Yours?
    By M65 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 01:53
  2. do ipods and the CD70 mix??
    By chris_20 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2010, 14:23
  3. any kits for ipods and standard
    By shaun86 in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2008, 16:00
  4. CDC 40 OPERA + Ipods....
    By Mercury in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2006, 23:38
  5. ipods for sale
    By redbullkid in forum Comedy & Humour
    Last Post: 3rd February 2006, 17:30
