Thread: Jumpy gear changes
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 2.8T 280 vxr
    Trim : 280 vxr
    Engine : 2.8t
    Default Jumpy gear changes
    Hey guys
    I have and automatic and tbh i dont know when the transmission oil was last changed
    Recently i have noticed it has become a much jumpier ride during gear changes in auto. And when i switch to semi auto it sometimes hestitates during gear change, like its in neutral for a second
    Can a oil change sort this problem or does it seem more major?
    The last owner said he kept it all well serviced etc, and i guess i took his word for it but the jerkiness is deffinately not right and just wondering if oil will make a difference at this stage or if its too late?
    thanks
    Regular Member gtr1000's Avatar
    Dec 2007
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Year : 2013
    Had the same with my 02 GSi when I bought it at 57k with FSH. Found out later that VX recommend a change every 4k or 4 years but is often overlooked by stealers.
    I eventually changed the box oil at around 65k and it made a world of difference.
    There's quite a few threads on here, some by me, so worth a look round here first.
    Jul 2009
    Derbyshire
    Trim : 280 vxr
    Engine : 2.8t
    Quote Originally Posted by gtr1000 View Post
    "4k", you mean 40? lol.
    Well thankyou. I'll check it later today as i believe it may probably have been neglected like yours too
    Just hoping there isnt lasting damage, as it does seem to be rather jumpy all of a sudden
    Dec 2007
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Year : 2013
    Senile moment (again), sorry. Yes, 40k.
    Regarding the delay in shifting when in "manual" mode - mine does it also, most noticeable under heavy acceleration at anything above 4k rpm. The wise old owls on here seem to think it's a trait of the AF33 box.
    Jul 2009
    Derbyshire
    Trim : 280 vxr
    Engine : 2.8t
    ye its mostly noticable whilst accelerating hard.
    Cheers for the info mate.
    Just called local vx dealers and got a price of £28+vat for the transmission fluid and £110+vat for the filter... didnt expect such a hefty price for a filter :/
    Feb 2009
    Devon
    Quote Originally Posted by Chuddy View Post
    If your going to do it then I would do it the proper way if I were you - i.e flush it all through the oil cooler pipes - that way you will get all 7.5 (approx) litres out and not just the 3.5 (approx) litres by using the drain plug. I did it the drain plug way and noticed a slight improvement in shift, but I'm going to do it the proper way now as I should have done in the first place and this should improve things even more (and also do the box itself no end of good)!
    I wasn't aware the AF33 had a filter fitted as standard (mine certainly hasn't)? but £110 & VAT is way too steep. I would try one of the magnetic aftermarket filters which can be picked up on ebay for approx £20 (from the USA) including delivery.
    I'll be picking up one myself up as soon as I've checked the diameter of the hose at the weekend.
  1. Jumpy start
    By richje100 in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 01:38
  2. cdti 120 jumpy
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 26th December 2012, 21:59
  3. Jumpy at 2000 revs
    By Planner in forum Engine & Drivetrain
    Last Post: 10th June 2010, 17:41
  4. Jumpy
    By davieboy1976 in forum General Chat
    Last Post: 15th August 2009, 19:01
  5. jumpy ride
    By TUX-VECTRA in forum Engine & Drivetrain
    Last Post: 28th June 2007, 01:59
