Results 1 to 10 of 24
Thread: Vectra 1.9CDTI 150 - Cold Starting Woes
    Oct 2007
    Ripon
    Default Vectra 1.9CDTI 150 - Cold Starting Woes
    Hi All,
    I've been scanning the threads about my current issue and find plenty having and living with and fixing the following.
    When my car has been stood for a while when starting from cold it takes about 5 - 10 seconds to get going .... runs roughly. There is some blue smoke that goes very quick and does not appear when running.
    It is in next week for a new manifold and egr ..... will this probably be the cause or any thing else I should look for?
    Cheers all
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    are you letting the orange coil light go out before cranking?
    May 2007
    GLASGOW
    Mines the same, it does have 110k on it tho
    Oct 2007
    Ripon
    Yep,
    Letting the glow plugs heat up 1st .... no spanner light when car getting warm so guess ok?
    Oct 2007
    Ripon
    Just passed 80000 today!
    Swirl bar in boot at mo, Booked in VX for new manifold for next week .....
    That may improve things.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by robdd1 View Post
    I reckon so mate
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    ive never had any cold starting problems with my vec even when i found that the swirl bar had fallen off. could be one of your glow plugs or an injector or even the leak off pipes either one could cause cold starting issues fella
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Just what I was thinking, a leak off pipe or loss of vacuum from some other pipe, check for hair line cracks by the clamps on pipes.
    May 2007
    GLASGOW
    where are leak off pipes situated?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Completely agree
    Reasoning behind the the inlet is if his swirls are sticking... but then he is getting no codes etc..
  1. Cold starting woes - Chapter 2
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2012, 17:46
  2. vectra 1.9cdti starting prob
    By dickyblade in forum Vectra C / Signum Troubleshooting
    Last Post: 15th August 2011, 10:29
  3. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  4. My Vectra C 2003 DTI cold starting problems solved hopefully
    By jameso in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2011, 15:18
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
vecyra 1.9 dead when cold
vauxhall vectra 1.9 cdti starting problems when cold www.vectra-c.com
1.9 cdti cold weather start problem
