Thread: P0110 fault code on GSi - damn!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default P0110 fault code on GSi - damn!
    Just when I've has a few weeks of no spanner light, the damn thing's back on again on start up for approx 5 seconds.
    Have read the codes and have got P0110. Having searched the forum, I'm non the wiser. Car starts fine (was a bit lumpy on tickover the other day but now OK), runs fine, in all, nothing that I would say gives cause for concern. But..........
    What should I need to look at?
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    hello matey, just had a look on my list and it comes upwith this HTH
    P0110 Intake Air Temperature Circuit Malfunction
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by lizard View Post
    D'you think this is MAF related? God help me if it is.
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by gtr1000 View Post
    wouldnt like say mate, but wouldnt surprise me...
    Full Member Big Sig's Avatar
    TAKEN FROM HERE
    Is there a temp sensor in the intake manifold for cold starts/hot climates/air fuel mix ratios???
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    TAKEN FROM HERE
    Will have a lokksee 2mrw but can't recall anything.
    For the past 12 months, I was getting P0070 on and off, which relates to "Ambient Air Temperature Sensor Circuit". I've not even bothered with this fault code as the car runs 100%.
    So P0070 goes away for a few weeks and P0110 takes its place.
    Could all be down to the same sensor going tits up.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    TAKEN FROM HERE
    Looks like the "intake air temperature sensor" is part of the MAF http://www.parksoffroad.com/tacomamo...de/cip0110.pdf.
    Oh dear . Will have to check all the usual stuff plus a MAF clean. Will see if this helps.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The air temp sensor is part of the same assembly. The flow sensor doesn't measure flow directly, but the cooling effect of the air flowing over a hot wire or film..... (ish)
    The temp of the air is needed to work this out. Outcome is the mass air flow.
    I would check the wiring and plugs before purchasing a new sensor unit.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Ste View Post
    Totally agree Ste, hence my other thread http://www.vectra-c.com/forum/showthread.php?t=100228.
    Have checked and cleaned all the associated plugs/pins/wiring and all seem fine.
  1. Fault codes p0110 & p0105. EML on. Stuck in LHM
    By halster78 in forum Engine & Drivetrain
    Last Post: 7th May 2012, 16:02
  2. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  3. damn car, latest nonsense is a p1112 code...
    By mark_w in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2010, 23:18
  4. Help with a fault code please.
    By craig-k in forum Engine & Drivetrain
    Last Post: 12th July 2009, 23:19
  5. Fault code ID
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 21st March 2008, 04:24
