Thread: Car kangarooing Help Please!!!!
    Jan 2010
    Wick
    Default Car kangarooing Help Please!!!!
    Hi, I have a 54 plate vectra 1.9 cdti sri 150, took off from tesco carpark today and there was virtually no power in the engine and I was stumbling along like a kangaroo, this went on for a good couple of minutes when suddenly the power came back and the car was going fine for a while then the same thing happened again. The car can be running along fine but very often when I reduce speed and go down the gears the same problem occurs with no power and going along like a kangaroo. The engine electronics indicator keeps coming on as well. There is also strong smell of fumes inside the car as well. Any suggestions?
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    check for air leeks. had this on my car it was an air leek
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    sticking egr valve or swirl bar fell off, remove and clean egr, details can be found in the how 2's section. the fumes will probably be coming from the knackered inlet manifold. or as below it could be a combination of both!.
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    use the 'search' button and look for 3rd injector in the string.. Will most likely be the cause of the problem
    Jan 2010
    Wick
    Thanks very much for your help. Hope its a simple/cheap job. It seems to be one thing after another with my Vectra
    Oct 2009
    lincoln
    would any of these faults cause a massive loss of mpg im only getting 40ish MPG and im treating realy nicely i have lack of power below 2000 revs kangarooing the lot
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by alsinky View Post
    if the 3rd injector is yellow thats the old one
    new upgraded one is blue
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Could also be the fuel filter, the engine may be starving
  1. Judder/kangarooing on take off
    By rec in forum Engine & Drivetrain
    Last Post: 26th August 2010, 19:06
  2. kangarooing at 2k rpm when warm
    By waspsno4 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 16:35
