Thread: EGR - Does this look normal
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default EGR - Does this look normal
    I've been getting the P0400 code so took the engine cover off today with the intention of cleaning the EGR, but this is what I was confronted with. Looks like the EGR is leaking oil somehow?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    take it off and give it a good clean any way, see what you come across.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    looks like a bit missing out of the gasket.
    Birmingham
    Looks like a burn of some sort. I bought one off the bay a while ago that APPARENLTY had the Vx recall done on it whereby they take out the solenoid and do things to it, that had a very simialr burn style mark in a very simialr place!
    Bye bye Vec B
    - Hello Siggy!
    Jul 2009
    Wiltshire, UK
    If the gasket is broken, is it ok to leave it like that if I take it off, clean the EGR up and put it back?
    Will the stealers even sell that single gasket? I know you can get them to go on the inlet and exhaust.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Looks like the solenoid has burnt out.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    ive had my car from new and had the egr off many times, there is no gasket there! on the cdti 150 but i see you have the 120, take it off and follow the how 2 and clean it AND the hole where it bolts to the manifold! dont forget the boost sensor while your at it. could it be that something has been left on top and got hot or melted?.
    Wales, UK
    clean both mating surfaces too
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes its just where gases and soot leak down the valve shaft.
    Jul 2009
    Wiltshire, UK
    Cheers guys. I won't get time to have a look until the weekend now.
    Don't think it's the solenoid otherwise the P0400 fault would be permanent, but it's only intermittent at the moment.
    I'm going to give it a good clean and see if it makes a difference.
  1. Normal or Way Out?
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 19:22
  2. is this normal ?
    By bigbranno9 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 10:41
  3. is it normal
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 4th January 2012, 22:24
  4. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
  5. ...Is this Normal??
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 18:58
