Thread: Creaking Drivers side front spring
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Question Creaking Drivers side front spring
    Heya everyone.
    got a small problem. ive had the car lowerd on standard shocks with eibach springs then 8 months have past and weve had this cold snap. now a problem had reared its head.
    there is a creaking coming from the drivers side front when i turn the wheel at slow speeds.
    took it to vauxhall and they said it was a dry top suspention bearing. tey said its nothing to worry about it might be dry or just worn slightly.
    also if its not this any ideas to what it could be? my springs do hacve the seat Mod done and they are still in place.
    Is it really nothing to worry about or is it actually somthing ill have to get changed ASAP?
    Thanks for the advice,
    Will
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Its nothing to worry about. It's like Vx said. It's the strut top bearing thats creaking and it only does it whilst turning at low speeds. Change the bearing andit goes away. I think that lowering the car may put more stress on the bearing as mine done the same and I changed both the strut top bearings.
    cambs
    Quote Originally Posted by arnie_barney View Post
    hi m8
    how much were the top strut bearings
    Nov 2007
    I can't really remember but I think they are about £15 each and take about 30-45mins eachto fit. You need to remove the strut and use a spring compressor. Then the bearing can be removed and repaced. Easy.
  1. Knocking from Drivers side front
    By sxi-dean in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2011, 16:18
  2. Squeaking From Front Drivers Side
    By Stephen S in forum General Chat
    Last Post: 16th June 2009, 21:20
  3. Drivers Side Front Door Card-SRI
    Last Post: 18th February 2009, 13:42
  4. Front driver side spring noise
    By barracuda in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2008, 11:23
