Results 1 to 10 of 24
Thread: spanner light on 5 mines only !!
    Regular Member nigec's Avatar
    barnsley
    Default spanner light on 5 mines only !!
    As above,
    The yellow car/spanner light sticking out of sunroof, comes on when you first start car up from cold, then goes out after about 5 mins. Starts up first turn and has done through the cold snap we've had. Only seen it for about a week. Not had any problems and car is running fine, Any ideas please ??
    Its a 56 plate cdti 150.
    Last edited by nigec; 17th January 2010 at 15:18. Reason: forgot to state what car
    West
    It's most likely you have a faulty glow plug
    barnsley
    How do i check ? is it tech 2 ?
    West
    If you know someone with a code reader have the codes read.
    barnsley
    Thanks ill ask about.
    Jan 2010
    Lancashire
    Just joined the forums to see if anyone has the same problem I have just came across with my 56 plate Vectra 1.9cdti SRi 150bhp.
    Bingo my problem is also the 'spanner via the sun roof' which has the car ticking over but will not run right away and then suddenly its like an injection of adrenaline. Car then has period of 'no go' and then suddenly clears. I will take it to my independant service garage in the morning for them to take a look at.
    Best Regards
    Allan
    Regular Member OSSY's Avatar
    Apr 2009
    I had exactly same issue over last few weeks - one of the four glow plugs was detached... Very easy fix for me - hope it is for you too...
    Sep 2009
    goole
    Default egr valve
    i had same with my 56 plate 1.9cdti and it was the egr valve vauxhall qouted 180 mate did job for 100 got part of internet for about 65 quid,cars runs like new now.
    barnsley
    Quote Originally Posted by OSSY View Post
    Where are they ? How to check ? and how to fix ? thanks.
    Jan 2010
    Lancashire
    Look forward to the glow plug info to see if one is detatched, car initailly ran like firing on 3 cyclinders then 'fixed' itself then went awol again.
    Looked in owners manual, page 37 suggest's might be diesel fuel filter?
    Will have a look in the morning.
    Best Regards
    Allan
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. Spanner light 5 times now exhaust gas light
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2009, 01:12
