Results 1 to 10 of 13
Thread: 1.9 cdti problem
    Jun 2009
    notts
    Default 1.9 cdti problem
    Car drove fine yesturday did 150 motorway miles.
    Drove car this morning and battery light came on and stayed, went shopping, car started fine, no light after 2 minutes it came on. Took car to a f1 autocenter who checked battery fine. Checked alternator and said it wasn't charging well 10v. Drove home and go 50 meters to house, car got noisy and powersteering light came on, no powersteering, and now tales ages to start, awaiting tow truck to take to vauxhall. any ideas
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Alternator...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Regular Member djr69uk's Avatar
    Midlands
    alternator. search my posts, it happened to me 2 weeks ago.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    check to see if the serial number comes within the recall batch,
    Scope: Astra H, Vectra-C, Signum MY 2004-2005
    Model - Plant - From - To
    Vectra C/Signum - Russelsheim 41080136 - 51000100
    Vectra C - Ellesmere Port 48066725 - 48110149
    Only vehicles equipped with a Denso Alternator (105A/120A/130A) and 1.9 Diesel engine
    listed in the VIN info have to be reworked.
    All vehicles reworked have to be cleary marked by a blue paint dot on the coolant expansion tank
    Release Date - 10 Nov 2006
    Jun 2009
    notts
    alternator and some springs. Don't know what springs, belt adjuster? Just waiting for warrenty company to say yes
    Jun 2009
    notts
    Got car back. New alternator under warrenty. Also new springs at each corner, they was cracked and changed under warrenty £750. But now car pulls badly to the right. 10 meters forward = 1 meter to the right. Should they have done the alignment?
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Idealy the alignment should be done once the springs have settled but it should not be pulling that much i have changed springs before and not had the alignment done,sounds to me as if a track rod end needs adjusting phone them and get them to get the car sorted as this was not how you left it with them.It really ****es me off the amount of people out there who cannot do their jobs properly!
    Jun 2009
    notts
    according to vauxhall dealer, all the work they've done will not have affectted the alignment/tracking. I wouldn't have thought you could have changed the springs without something moving, i.e. top mounts etc.
    Aberdeenshire
    The top mounts will be in the same position as theres only one way they fit these shouldnt have any affect on the alignment if they have been refitted correctly just get it back to the garage for them to sort it.It will more than likely be somthing minor that needs adjusting.
  1. Cdti 120 problem
    By Vidar in forum Engine & Drivetrain
    Last Post: 26th December 2012, 00:25
  2. Problem With My CDTi
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 09:30
  3. 1.9 CDTI problem
    By chrish in forum Engine & Drivetrain
    Last Post: 26th September 2008, 10:17
  4. 1.9 CDTI 150 BHP problem
    By sumpyboy in forum Engine & Drivetrain
    Last Post: 18th July 2007, 21:31
  5. CDTi MPG? do i have a problem?
    By Andy in forum Engine & Drivetrain
    Last Post: 9th November 2005, 17:49
