Thread: Brake Spring
    Tarbert
    Default Brake Spring
    Hi just replaced the rear pads on my 1.9cdti. Slight problem in that one of the Caliper Springs broke when trying to get it off. Does anyone know if it will be ok to drive the car until I get a replacement one to put on? thanks
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    The spring secures the caliper. I forgot to fit mine and I noticed a slight wobble in the caliper. I sure it will be fine to drive but please please check out yourself. I did notice that Halfords sell the springs in the brake pad bit of the shop. Hopefully they are a common fit.
    Tarbert
    Just taken it for a test drive and it seems ok. so guess it should be ok till I get a replacement. cheers
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Replace ASAP. Your brakes will feel better after.
  1. rear brake retainig spring
    By grant2258 in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2012, 11:11
  2. Knocking brake and Snapped spring
    By Thom in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:37
  3. 314mm brake pad removal spring
    By DHobbs in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2012, 00:19
