Thread: Parrot Bluetooth
    Northampton, UK
    Default Parrot Bluetooth
    So where did you guys put the big Bluetooth box thing? The first time I fitted it, I put it behind the climate control and heater buttons, but it interfered with my CID. Also, the Bluetooth streaming is really bad, if your sitting still, it's normally ok, but as you move it skips and jumps like a scratched cd.
    Since fitting it, I've had a horrible rattle noise that, by searching the forum sounds like a shock has gone, I'll look at that too, but seeing as its only come since then, I doubt it's the shock.
    Cambridgeshire
    I placed mine in the side panel of the passenger footwell. It's tucked down there with most of the cables so that I could get the stereo unit back in.
    Hope this helps
    Northampton, UK
    Cheers parsco
    I Probably should have said, I've currently put mine behind the glove box.
    West Midlands/South Staffs border
    Hi,
    Have put my MKi9000 on the shelf behind the heater controls, have no problems with the bluetooth, or the displays.
    WGAF#5
    and mine sits between the radio and the glovebox on the angled "bracket"
    no problems or interference
    Northampton, UK
    I cant believe it, i just tried to update the parrot software, then half way thru i get a windows error message and blue screen of death!!!!
    Now I can't get the software to update!
    It seems to still work, but won't connect to the pc.
    I hate windows so much!!!!
    Any ideas how to flash the bluetooth module on the parrot???
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by n_hudson View Post
    I'm trying to do this myself. You can do it by cable or bluetooth, i'm trying it the bluetooth way but cant get it done. I think its "blueunplugged" that you can send it too and they will do it for you. My Satio's having a hard time with the old firmware.
  1. Parrot bluetooth
    By dunkymunky in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 13:07
  2. Bluetooth parrot help
    By parsco in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 20:36
  3. parrot bluetooth
    By c1287 in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2008, 21:30
  4. Parrot Bluetooth
    By Padster72 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2008, 21:42
  5. Parrot Bluetooth HU
    By Spikey© in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2006, 10:50
