Thread: Light on.. limp home mode when warm.... any help plese ???
    west midlands uk
    Default Light on.. limp home mode when warm.... any help plese ???
    Hi there i have a vectra 2001 cdx 1.8.. Then engine light came on ( the orange light to the left hand side looks like an engine ???) The car will drive fine intill its warmed up like 15 mins or so then it will go into limp home mode also if you drive it then turn off the car without it going into limp home mode if you go back to the car while its still warm it will still be in limp home mode.... I have recently changed both lambda sensors the mass air flow sensor plus it had a service not long ago when all filters, sparks and oil were changed.. any ideas what the prob could be ?? (Without a code reader)
    thanks in advance
    Lester
    Regular Member cphaza's Avatar
    Hertfordshire
    this is the vectra c website, you are refering to a vectra b. Google 'paperclip test' or go to www.vvoc.com to cure this one
    Hertfordshire
    11 Post(s)
    Quote Originally Posted by cphaza View Post
    Don't think you can do the paperclip test on a 2001 Vectra-B. It's too new. Only works on cars up until 1999 or 2000 I believe.
    west midlands uk
    thanks guys... ive just ordered a code reader ( i didn't realize they were so cheap) i will let you know of the outcome once i find out myself. thanks
    west midlands uk
    slight update... i got the code reader and 2 popped up, code 0135. with the message o2 - bank 1 sensor 1 ( i take it this is the sensor before the cat ? as i did change this 1 already maybe i got the wrong part ) and an ignition coil fault.
    can anyone confirm the correct engine number for a 2001 cdx vectra 1.8
    I cleared the codes but within a few mins they were bk on .
    Birmingham
    Mate, I had a VERY similar issue on my Vec-B SRI DTI 2 weeks ago.
    Car ran fine cold, as soon as it got to normal running temp, EML on, no rev counter and rev's hunting at idle.
    When left to cool down, fine again until back to running temp. Turned out to be the crank sensor.
    I know yours is a petrol and mine Diesel but similar symptoms!!
    Here's my original thread, in case its any help: http://www.vectra-c.com/forum/showthread.php?t=99408
    Bye bye Vec B
    - Hello Siggy!
    it will probably be a z18xe but could be a x18xe if its not got the fly by wire throttle
    west midlands uk
    thanks for the help so far guys.. My previous o2 sensor i ordered was for the z18xe, if this was the wrong one this could explain 1 of the faults ? i dont know if its fly by wire.. is there a way to find out, is the engine number printed anywhere
    If you can see a throttle cable going to the inlet manifold then its a x18xe, although I would imaging the o2 sensors are pretty much the same across these engines.
  1. 04 2.2direct spanner light and limp home mode
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 13:45
  2. Exhaust Emissions Light Limp home mode
    By corby-boy in forum Engine & Drivetrain
    Last Post: 5th August 2009, 20:53
  3. limp home mode but no spanner light??
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 12:22
  4. Back in the dealership!!! Emission light glowing / limp home mode
    By Doug-SRidirect in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2006, 12:05
astra limp mode when warm
opel vectra b limp mode when warm
car goes into limpmode after warming vp.
car goes into limp mode when hot
vectra c limp mode when warm
opel astra limp mode when its warm
engine goes into limp when warm
astra g limp mode when warm
vectra limp home when warm
limp mode when warm meriva
engine goes into limp mode as engine warms. astra
vectra diesel limp mode when warm
car goes into.limp mode.when warm
car goes into limp when you drive off quickly when warm
why does my astra drive fine when cold then goes into limp mode when warm
z18xe in limp mode when restart and hot no eml
vectra 1.8 limp mode when walm
vectra car warm goes into limp mode
vauxhall astra fine when cold limp mode when warm
opel meriva goes into limp mode as soon as it gets hot what can it be
