Thread: Interior light fault
    Warwickshire
    Default Interior light fault
    Hi I have an ex police 2005 vectra. None of the interior lights work? has any body come across this before. I have carried out the basic checks of checking the fuses. they work when you open the doors but not of either of the switches. Thank you Tom
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    have you checked if its pluged in in the boot? (left hand cubby hole.. check for broard white wire...)
    Warwickshire
    Hi Ken thanks for reply yes it was unplugged in the boot plugged it in all 3 now work when doors are open however still doesn't work off the switch?
    If it makes any difference they turn off when they are on from the switch so I can't understand why they dont work?
    Thanks, Tom
    Engine : 2.2 Direct
    it could be a faulty switch! (your light panel is with how many buttons?)
    there are with 1, 2 and 4... (maby even 3 im just not sure thats made...)
    to turn them on it should be the 3 away from the driver (in a RHD)(if i remember correctly)
    Warwickshire
    Hi Ken its a 2 button switch one looks like a TV power button?? the other looks like a sidelight button??
    Will test the switch before I go to work. Would a faulty switch knock the front lights out and the lights above the rear passengers??
    Thanks very much, Tom
    Engine : 2.2 Direct
    The OEM funktion should then be (cant remember with of the switches that does what)
    1: turns on front and rear light
    2: turns off the front light (not the rear if OEM fitted)
  1. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  2. Interior light fault
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 10:54
  3. interior vent fan fault
    By toofarfalls in forum Bodywork & Interior
    Last Post: 6th October 2008, 21:14
  4. interior light fault. help!!!
    By vecsxi in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2008, 00:11
  5. interior light fault
    Last Post: 12th February 2008, 20:22
vauxhall vectra interior light fault
