Thread: windscreen washers
    Aug 2009
    oswaldtwistle
    Default windscreen washers
    can anyone help,front windscreen washers not working properly, slight trickle out of jets.fitted with insignia jets how do you unblock them and pipes,andhow big of a jobis it to replace pump.... thanks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Worth using some compressed air to clear out the pipes. If not it may be that the filter in the washer bottle needs a clean.
    Bumper off job to remove the pump
    Aug 2009
    oswaldtwistle
    thanks will give the blow job a go lol...... bit stupid that you av to remove bumper design error methinks,,,,,thanks again
    Mar 2007
    North East
    A how to
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    you don't need to take the bumper off as you can get your hand in there unless its a shovel..........
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    you dont need bumper of for pump off mate i done it without
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Bumper off is to much of a hassle for a simple job..jack the nearside up and turn the wheels to the right full lock.. undo 3 x torx screws and pull back inner arch to gain access to pump..remove clean and refit..job done!
    Aug 2010
    n ireland
    just cleaned mine out todqay guys this has been great help
  1. Windscreen Washers
    By Bloicy in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 22:42
  2. Windscreen Washers
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 22:04
  3. Windscreen Washers.......
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 16th December 2008, 23:25
  4. windscreen washers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 19:04
  5. Windscreen washers
    By T4M in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 23:33
