| Home Page | Register | Forum Rules | FAQ | Merchandise Shop | Garage | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Notices |
Thread Tools |
#1 |
VW Sharan starting problem
the other cars a sharan, n reg, 130k, we've had her 3 year and she's a great workhorse
always starts first click no matter how long it was since she was last used....... until the last couple of weeks..... now sometimes on the first start of the day the engine just spins and spins until you stop then it gives a 'cough' as the key is turned off, second time of trying spins a bit then cough cough starts really lumpy then revs up and is fine for the rest of the day any ideas what to start looking at first?? |
#2 |
Full Member
Sounds like a fuel problem,maybe cold start solenoid,when was it last serviced???
__________________
#5 | |
Full Member
Quote:
![]() ![]() ![]() omg thats really spooky,my partner has the same car but a p reg 2.0 and has done 136k miles and its a right heap and its done the exact same thing,it wud start of a morning but was rough running as if it was on 3 cylinders then we`d go out then stop the car then 10mins later and try to re start it but failed and had petrol fumes smell but after about 10 mins it wud start but rough as a bears ar*e,it was worse than this especially if it had been raining all night and damp the next day so i thought fu*k this and had a look under the bonnet and surprise to me i found 3 small diameter hoses loose and wasnt doing anything so i found in were they shud connect to but 1 of the hoses that ran from the fiel injector rail has snapped off a valve at the back which is inline of the brake servo hose above the air filter,i re-conencted the other 2 which were loose at the front of the engine and then we again started to use it and since then its been a great runner,starts first time and lot smoother,just have to get that valve to replace but its still going well without any starting/running problems. this sharran is really going to be replaced with a zafira soon as i can ![]() ![]()
| Bookmarks |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2.2DTI Power loss and starting problem | grslewis | Engine & Drivetrain | 2 | 21st April 2008 15:38 |
| Starting problem | cmcl | Engine & Drivetrain | 4 | 5th April 2008 20:57 |
| My Vectra C 2003 DTI cold starting problems solved hopefully | jameso | Troubleshooting | 4 | 7th March 2008 20:12 |
| Astra G 1.7TDI Starting problem | john_k_sri | The 'Off Topic' room | 1 | 17th February 2008 00:18 |
| Starting problem | david173 | Vectra C / Signum Car Chat | 11 | 24th July 2006 09:02 |
