Results 1 to 2 of 2
Thread: 1.8 vvt - engine rattle on start up
    Regular Member Misty Design's Avatar
    Tamworth
    StatsVehicle Info
    Default 1.8 vvt - engine rattle on start up
    I've started another thread on this matter as it was taking another off subject.. " 1.8 vvt, is it really that bad? " http://forum.vectra-c.com/showthread...796#post611796
    Quote:
    Originally Posted by Hazard
    took it into vauxhall yesterday and they said theres no fault so i left it with them over night so they could start it from cold this morning and still no fault they recon, so im taking it to a non vaux dealer to get a proper diagnosis and then take it back to vaux with the mechanics report.
    **** dealers
    thanks for remembering to report back Hazard, i had exactly the same diagnosis when i first reported it. Only occurs for 1 or 2 seconds & on an immediate 2nd start it doesn't occur again. I think they jumped into the car, fired it up - realised the radio was on & couldn't hear, switched it off & missed the problem.
    I had a non related problem this week meaning the car was in at the dealer, i did discuss this rattle on start up problem with them - i was advised Vauxhall are aware & there is a bulletin advising it is related to the use of long life oil (fully synthetic), after an oil change the noise will be less apparent, but after a while the oil is that thin it is draining out of the tappets, on restart you get the rattle until they are pressurised with oil again - if the noise dissapears within 10 minutes, take no action!
    I'm concerned about it at 2 seconds after every standing start!
    I asked to see the bulletin, but was told i was not allowed! next step to get the bulletin number and i'll get it from my contacts in Vauxhall fleet.
    StatsVehicle Info
    they do suffer from drain back...and another reason to keep that oil in tiptop condition and to ignore the 20,000 mile cahnge interval..... 10,000 is much better for the car..
  1. rattle on start up
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 22:16
  2. Engine Rattle on start up
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 29th December 2011, 17:57
  3. Rattle on start up
    By Vectracdti150 in forum Troubleshooting
    Last Post: 24th February 2011, 23:34
  4. rattle on start up
    By ant6566 in forum Engine & Drivetrain
    Last Post: 11th April 2010, 19:05
  5. engine rattle on start up
    By craigyboy in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:35
vectra vvt tappets on startup
vectra c 1.8 sri rattly on start up
https:www.vectra-c.comforumshowthread.php51140-1-8-vvt-engine-rattle-on-start-up
vectra c rattle on startup
2007 vectra rattle on cold start
vectra c 1.8 cold starting problems
vectra rattle on startup
08 vectra rattle on startup
vauxhall vectra automatic engine rattle
vectra c 1.8 engine rattle on cold start up
