Hi all
I have the above code on my vectra c 55 reg on the net it says it's a SBDA fault can anyone help with this. The car starts ok stops ok spanner light is only on when I start up then it goes off my reset after 25 starts.
Thanks steve
Hi all
Thanks steve
P1613 is related to your imobliser on your key , this one is a bit of a grey area fault code . If you have the immmobiliser button on the key fob press it whilest the key is in the ignition and switched on ,it may of just divorced itself and just need resyncing.
and still loving it
On my key fob only have the old one ie two buttons at the front and one behind to open the boot
Press the door open im sure if its not that try lock door lol
[QUOTE=Mark-R;1896986]Press the door open im sure if its not that try lock door lol[/QUOTE
Thanks m8
