Thread: Noise from engine. May be high oil pressure.
    May 2012
    Catterick garrison
    Unhappy Noise from engine. May be high oil pressure.
    Hi, I ve got vauxhall vectra sri 07 plate. Recently a light on the dashboard i.e car with a spanner came on. I took it to the garage and they did diagnostics on it but couldnt find the fault. The engine is making quite a loud noise so they recommended me to change the camp belt as the car has done 51000 miles. So i did but no luck. The garage has told me now dat it could be oil pressure as it should be 1.4 but mine is 4. something. Now he has asked me to take it to vauxhall tech. What does it mean?? Is it serious?? Please help.
    South east
    You'll have to give us a small clue as to which engine you have...
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    And elaborate on the noise?? High pitch? Changes with engine revs? Changes wen clutch depressed?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Sounds like a blockage in the oil ways, Something will be starved of oil,
    Looks like an engine strip or replacement.
    May 2012
    Catterick garrison
    My engine size is 1.8. How much will it cost for engine strip or replacement???
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by Shaben View Post
    It probably means he don't know jack ****!! & he's stumped & don't know what to do next, see if anyone else here can come up with any answers.
    scotland
    Thumbs up johnboy ab
    try camshaft solenoid valves these cause pressure changes and loud camshaft noise. cost 100 pair of e bay done mine twice 130,000 miles on clock. noise goes away above 2000 revs is a pointer to this fault they clog up with gunk.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by johnboyab View Post
    what johnboyab said above
    have a look at this post
    It's the VVT mechanism.
    I have a thread open about it now. One of the the servos have broken. Do not run the car without them, they starve the VVT of oil (the clacking noise), and you'll end up with broken pulleys and bits of metal all over the place. get a new set from VX and bang them in. Takes about 10 mins with the right sized socket... I think they cost about 80-100 for the part.
    But do NOT drive the car.
    have a read of this post part numbers here as well
    http://www.vectra-c.com/forum/showth...No-Power/page3
    Regular Member C-Owner's Avatar
    May 2011
    South London
    This applies to the xer engines
    {Quote}
    try camshaft solenoid valves these cause pressure changes and loud camshaft noise. cost 100 pair of e bay done mine twice 130,000 miles on clock. noise goes away above 2000 revs is a pointer to this fault they clog up with gunk."
    Model Year
    2008-2011
    Vehicle Line / Condition
    Astra, Aveo, Cruze, Wave - Engine lack of power with DTCs P0011, P0014, P000A, P000B, P0012, P0015 or engine rattle noise
    Do This
    Remove the oil filters from the camshaft position actuator solenoid valves
    Don't Do This
    Don't replace the camshaft position actuator solenoid valves
    Reference Information / Bulletin Number
    10-06-04-016
    Remove the inlet solenoid, plug the hole to stop excess oil spillage.
    Remove the 2 orange filter bands and the black end cap filter from solenoid.
    Refit solenoid
    May 2011
    South London
    As above but be careful as yours is 2007 the solenoid thing applies to the 1.8 xer's
    Cant edit my post to include the solenoid picture so its here.
  1. Brand new dpf still got high differential pressure
    By littleshanks in forum Engine & Drivetrain
    Last Post: 14th January 2012, 15:54
  2. High pressure pump leaking!!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 21st November 2009, 22:14
  3. High pressure fuel pump
    By dougiemc in forum Engine & Drivetrain
    Last Post: 3rd May 2009, 21:32
  4. High Pressure Water Warning..
    By spoons in forum General Chat
    Last Post: 25th January 2007, 17:41
  5. Turbo, low or high pressure
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2006, 20:54
corsa c engine rattle high oil pressure
