Results 1 to 10 of 18
Thread: Air recirc servo fixed for free!
    West Sussex
    Default Air recirc servo fixed for free!
    Anyone else tried this? I had the clicking sound from under the dash so I removed the air recirc motor thing. I wanted to see what was inside so I opened it up and couldn't believe I would have to spend £70 just because one tiny plastic tooth have broken off. I decided to fix it by gently levelling the area where the tooth was missing and made a new tooth from a piece of old toothbrush handle which I glued in place with Araldite (about as strong an adhesive as you can get)
    I made the new piece oversize, placed it on the
    glue with tweezers, shaped it when the glue had fully cured, job done!
    The picture shows the new piece before I shaped it with a nail file, dead easy!
    Attachment 42854
    Attachment 42855
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    like it !
    West Sussex
    Quote Originally Posted by Al 22 dti View Post
    like it !
    And here it is with it's new tooth!
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    does anyone know the part number for this?
    My air recirc just clicks when pressed.
    Is it hard to change?
    West Sussex
    Quote Originally Posted by monty2000 View Post
    Don't know the part number but it's reasonably easy if you don't have fingers like sausages. The really hard part I found was getting the screws back in and enough light around the area. Also a good idea to make a note or take a photo so it all goes back in the right place.
    Sep 2009
    Glasgow
    tried several times and new tooth breaks free, used the same glue as you, what is the part called in terms of gears.
    Dec 2010
    London
    8 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    23 -Motor, Servo, Air Recirculation Flap, With Lever 13192013
    Mar 2012
    Ireland (Kildare)
    the hardest part is getting those screws out... must need a tiny torx screwdriver!
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    The most secure way to repair this cog, would be to weld a piece of plastic in, of the same material, and then file it to shape.
    I have never found araldite to be that tough...you would at least need a good plastic glue compound.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I totaly agree with you on that one Robsey.
    My Recic servo packed up last month and I too found this thread in the hope that I could do the same but found that two of the cogs had broken on mine, so will either go out and buy another or see If I can locate one at a local scrappy (considering the price of them)
  1. Looks like I've got the dreaded recirc servo failure
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2012, 20:10
  2. Recirc valve on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 22:22
  3. Brand new genuine air recirc servo motor
    By SRiXPT in forum Parts for sale
    Last Post: 5th July 2010, 14:45
  4. Air Con Recirc
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 20:47
https:vectra-c.comforumshowthread.phpt=138933
