Thread: fault code p2279
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    StatsVehicle Info
    Default fault code p2279
    i have a warning light on, and my code reader came up with fault code p2279 intake system leak, i have read on other posts that this could be the egr valve, bur i only lately topped up my coolant bottle and i noticed that i did not fully tighten up the cap would this cause a warning light to appear.
    StatsVehicle Info
    34 Post(s)
    4 Thread(s)
    You have an inbalance in the vacuum system , check your vacuum hose connectors for splits or signs of perishing , also check the turbo hoses for splits
    and still loving it
    Apr 2008
    nothern ireland
    StatsVehicle Info
    well tightened the coolant bottle cap, still have a hissing noise above 2000 revs when below this the noise is gone, will look for split hoses 2morrow, i hope its not a leak in the intercooler, i have a spare egr valve will replace this to see if thats the prob, but dont know if the egr would cause a hissing noise above 2000 rpm
    StatsVehicle Info
    34 Post(s)
    4 Thread(s)
    Sounds like one of your intercooler hoses has a split in it
    and still loving it
  1. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. P2279 code. 1.9 150
    By Mopar Man in forum Diesel Engine related
    Last Post: 28th April 2011, 20:45
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
