Thread: P0340-28 Camshaft pos sensor circuit range/performance???
    Jan 2010
    wirral
    StatsVehicle Info
    Default P0340-28 Camshaft pos sensor circuit range/performance???
    Just plugged the vec in as I had a very brief "flash" of the car/spanner on the first start up this morning and got the above code/description.
    The car/spanner did NOT stay illuminated and the car is running fine.
    Anybody got any ideas???
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    StatsVehicle Info
    P0340 is camshaft position sensor circuit malfunction.
    If the car is operating normally, then don't really worry about it for now. May just be a glitch.
    If it happens again, then check the plug for good connection.
    I know all about this fault code for my car......
    What engine is it?
    Jan 2010
    wirral
    StatsVehicle Info
    Its the 1.9cdti 150 bhp, think the engine code is z19 DTH, and its a 56 plate estate (design)
    Where should i look for the "plug", I have no idea where the cam shaft sensor is!!
    I have had the cam belt/kit done at 82k, 18k early if that helps any!!
    also, it has flashed up once before, the morning after I changed the glow plugs.....if that makes any difference
    StatsVehicle Info
    I knew you had a 150 when i read your post!!, the sensor wires are just bellow my finger!, I'm actually pointing out the cam timing bung, but you can see the sensor wire & another, I've cut the original tie & pulled some 'slack' up towards the sensor, i had this fault a dozen times & it turned out to be a tight wire pulling & causing a dodgy connection. hope yours is as simple, .
    Jan 2010
    wirral
    StatsVehicle Info
    That kind of makes sense mate, as recently, when i removed my plastic engine cover, i did notice some signs of rubbing on its underside from around that area. almost as though i have fitted it slightly wrong and its pressing on some wires.
    Thanks a lot for that, i'll check it out later
  1. Camshaft Sensor Error (P0340)
    By Kaput in forum Engine & Drivetrain
    Last Post: 16th February 2013, 16:53
  2. Replies: 3
    Last Post: 13th August 2012, 22:25
  3. Replies: 2
    Last Post: 24th June 2012, 02:11
  4. P0340 - could it be crank sensor?
    By rich r in forum Engine & Drivetrain
    Last Post: 25th December 2011, 19:00
  5. Replies: 4
    Last Post: 2nd October 2010, 14:58
https:www.vectra-c.comforumshowthread.php117906-P0340-28-Camshaft-pos-sensor-circuit-range-performance
p0340-28 vectra
P0340-28
vectra p0340
p0340-29 vectra c
p0340 vauxhall zafira dieselOpel P0340vectra c 1.9 cdti p0340astra 1.9cdti P0340p 0340 opel vectra cvectra cdti performance camshaftvauxhall insignia diesel camshaft sensor vectra c 19 diesel cam shaft sensor p0340 vectrap0340-29 opel vectrap0340 camshaft position sensor circuit rangeperformancep0340 vauxhall vectravectra c p340-29vauxhall vectra c p0340sensor range performance opel vectra cp0340 vectra cP0340 - Camshaft Position Sensor Circuit RangePerformance (28) - Not presentcamshaft sensor range performance zafirap0340 suzuki rangeperformance
